Old 06-12-2004, 11:58 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
New Problem... "fuel filter"??
Mudder, thanks for your reply to my last post. The reason that I changed my fuel filter in the first place is, that Im getting my truck ready for some long hauls to Tx this summer. Last time I went, there were a couple times that my truck "studdered".. and so I thought I would just change it out. Prevenitive maintenience. After I changed the filter, I started my truck, reved it a few times and let it run for several minits. Well today I started to work and it just up and died on me, no studder no jerking, nothing. just died. I got off the road and she fired right back up, Air in the line mabey? I took a chance, got back on the road, it died at least 10 times with in 5 miles, a couple times she studdered first, I had to put er in N and fire up- while moving,,, was REALLY scarry as there was no where to get off the road. Finally made it to a church parking lot, called my sister, she came and followed me back home, My truck only studdered one time on the way back, then she ran just fine. What could possibley be the problem?? The ONLY thing that I did was change that filter.I know I have it in the right way and got everything back the way it was. Im at a loss
Thanks in advance !!
junk
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 06-13-2004, 12:45 AM   #2
Jeepster376
Jeepster376's Avatar
Is your fuel pump OK? Are you sure it's a gas problem? I think if your starvin the carb of gas, it wouldn't fire back up so quickly, as you would have an empty bowl that needs to refill somehow. I would think about it being an ignition problem.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 06-13-2004, 01:22 AM   #3
neonlarry
neonlarry's Avatar
^Do you have an HEI? If so sounds like when a module starts going bad.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-13-2004, 07:09 AM   #4
dwaite72lnghrn
When the fuel filter was changed you might have gotten dirt in the line that plugged the jets or some thing. If the filter went before the pump it could also show a bad fuel pump for what it is. When it studders and dies pop the air cleaner off and hit the gass peddle and see if fuel squirts from the accelerator pump? That might tell you if the bowl is empty(Starving for fuel). If you pull the cleaner and you smell a lot of gas the fuel bowl might be overfilled (clogged needle on the float) which could cause the same thing. Just a guess.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-13-2004, 08:02 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Ignition problem.
Jeepster is right, you'd probably have to crank awhile to refill the carb with fuel if it was a fuel problem. Also, when starving for fuel, they usually fall off while running rather than cut out.
Old 06-13-2004, 09:20 AM   #6
cdowns
cdowns's Avatar
to test the volume on the fuelpump disconnect the line into the carb put it into a jar or can and crank the engine for 30-40 seconds the factory specs is 1pint of fuel, for 30-45seconds of cranking. if you're not getting that volume you've either got a bad fuelpump or a glogged fuel pickup in the tank
Old 06-13-2004, 09:22 AM   #7
BOSS
Just here to help
BOSS's Avatar
I would check the wire that goes to the dist.Mine was acting the same way and it took me forever to find out what it was.I also had to change the modules inside the dist,sounds more like ignition then gas.Good luck.
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 06-13-2004, 11:06 AM   #8
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
I GOT IT!!! Was the STUPIDEST thing... The new filter I bought came with a rubber gasket "thingie" that went all the way up inside the filter, inside that was a white plastic "thingie" and a small spring... The filter I took out didnt have this. I THINK that the pressure of the fuel was not enough to depress the spring "thingie" and let the proper amount of fuel into the filter. I just ran it about 10 miles, and she ran like a dream!! Was a small thing, but dammit, I CONQUERED it!!! HA HA!!!
Thanks everyone for your helpful input!!!
~"GROUP HUG"~
Old 06-13-2004, 11:26 AM   #9
junkyardjohn
junkyardjohn's Avatar
JODIE --- I'M NOT SURE OF WHAT YOUR PROBLEM WAS , BUT I'M SURE GLAD YOU FOUND IT, & FIGURED OUT A CURE. CONGRATULATIONS ON NOT BEING A HELPLESS PERSON WHEN IT COMES TO TROUBLE SHOOTING YOUR PROBLEM. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-13-2004, 12:21 PM   #10
fast71
Drive it like U stole it
fast71's Avatar
Talking
Jodie , I was reading your post and I was going to say the same thing that you found. they make to style filters for the quad one has a paper gasket on the end ant the other has the rubber with the check valve . I work for Advance Auto parts and when I sell the one with the rubber end I always open it and do away with the check valve before the customer has a problem.
Brian
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 06-13-2004, 12:53 PM   #11
dinnut
dinnut's Avatar
so where you going in texas?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 06-13-2004, 01:11 PM   #12
BOSS
Just here to help
BOSS's Avatar
Glad to hear you got it fixed,sorry my advice was wrong......lol.Good thing you didnt listen to me.
Support our site
Norwood Survivor
Old 06-13-2004, 03:27 PM   #13
Bowtie67
Bowtie67's Avatar
~"GROUP HUG"~
And you claim you need a Truck Buddy? I think you dd exceptionally well at backtracking what you did to find the problem. You deserve a couple of atta girls...
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 06-13-2004, 05:04 PM   #14
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Junkyardjohn... Thanks.. Sometimes its hard NOT to feel helpless tho when youre stuck on the side of the road, 100 degree temps with 100% humidity, lol... just gotta keep saying, "it'll be OK!!"..
Fast71... Thanks!! and thanks for saving others, headaches
dinnut... Will be goin to Galveston about 4 times between Sept and Nov. Taking my daughter there for surgery at the Shriners Hosp.
Purple.... THANK YOU for your advice, I never turn away advice, next time if something hapens, I can refer to what you told me!!
Bowtie,,, "Atta girls" are most excellent!! Ill take all I can get!! .. But would still be REALLY nice to have a "truck buddy" or 2 for things that are way over our heads
Old 06-13-2004, 05:12 PM   #15
Tx Firefighter
I'm sorry that you're going through problems with your daughter. I hope all is well for your family.
There's no need to be stranded in the Lone Star State. If you break down in Texas, I'll come give ya'll any help you need. I can bring my diesel truck and car hauler trailer if needed.
Old 06-13-2004, 09:04 PM   #16
krue
Designated A-hole!
krue's Avatar
That applies to the rest of us along the way, just let us know when you are passing thru!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-14-2004, 05:20 AM   #17
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
TxFF and Krue.. Thank you both SO much. Every time I make one of these long trips, I always post it here on the board, and Ive never left home with less than a dozen numbers between Ga and Tx, to call incase of an emergency. Thankfully Ive never had to call for a break down, only a hurricaine (Thanks PapaNoel ) Having thoes numbers with me is one of the greatest piece of mind I can have... THANK YOU!!
junk
Old 06-14-2004, 05:47 AM   #18
jlive68
help
I don't think you would come through Pensacola but if you need anything let me know. Email me and I'll give you my number.
1968 chevy
U.S. Navy
jlive68 is offline   Reply With Quote
Old 06-14-2004, 07:10 AM   #19
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
jlive68... actually I go right thru Pensicola!! ... Thank you I appreciate it!!!
Old 06-14-2004, 11:43 AM   #20
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm proud of you, got it figured out and fixed - that problem would have got the better of alot of us.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-14-2004, 12:00 PM   #21
Mudder
Mudder's Avatar
Good job Jodie...........
Mudder is offline   Reply With Quote
Old 06-14-2004, 12:25 PM   #22
dubie
dubie's Avatar
I have such admiration for all the ladies on this board that like to get down and dirty.......oh ...........hehe....and the ones that like to work on their own trucks to
Good Job Jodie!!! I'm a great feeling when you can solve the small problems on your own. Gives you a great sense of accomplishment.
I am happy to have a wife that takes such a thriving interest in trucks. I couldn't have gotten this far without her help....................or her money
Once again GOOD JOB!!! More attagirls for you
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
