Old 06-13-2004, 01:16 AM   #1
CG
BlahBlahBlah
71 1/2 ton 4x4 rearend needed
any washington members have a complete ready to bolt in and go rearend for sale for 71 half ton 4x4? drum to drum, all i want to have to do is hook up the brake line and emergency brake cable.
Old 06-13-2004, 10:01 AM   #2
Mark70Z
I do in Peoria, Illinois. 250 + shipping from 61607. 309-365-9300 $25 to crate.
Mark70Z is offline   Reply With Quote
Old 06-13-2004, 12:50 PM   #3
CG
BlahBlahBlah
wish you were a little closer...
Old 06-16-2004, 01:24 AM   #4
CG
BlahBlahBlah
no one huh? how bout if i expand to oregon....anyone?
Old 06-16-2004, 05:57 AM   #5
LeRoy
Registered truck nut
LeRoy's Avatar
What gear ratio do you need? Also, does it have to be a 71 4x4 rearend not 69-70
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 06-16-2004, 09:01 PM   #6
CG
BlahBlahBlah
i have no idea what the gear ratio is, as far as a 69 or 70 goes i dont know if they will work or not. all i know is it has leafs and i need the drive shaft to be able to bolt up and it has to have the half ton bolt pattern...well i think thats all i need???? so what you got and how much you askin?
Old 06-17-2004, 08:17 PM   #7
CG
BlahBlahBlah
leroy i got this reply from jimshortstep on the board....
The 69-70 4x4 rear ends are a direct bolt in. The two wheel drive leaf spring rear ends are not a direct bolt in. The 69 and some 70 rear ends are 1 1/2" narrower than the 71-72 rear ends....
ok now that i know that do you have a rear that would work for my truck?
