Window installation
Need some tips on installing back window in my truck (small window). I undersand it gets threaded in with a rope, but I sure would appreciate any helpful advice before I start.
Thanks DR67
Dave Knoxville,Tn. |
Put the gasket on the glass. Then take a piece of small rope, I have even twisted together 3 or 4 pieces of masons line in a pinch, and tuck it into the groove that goes onto the body. Start at the bottom and go all the way around and overlap it back at the bottom. Then put the glass against the body and have some body hold it there, make sure it is centered, don't favor the top or bottom, just hold it where it is going to sit when done. Then go inside the caband start gently pulling on the string, so that the gasket starts coming over the edge of the lip on the body. You may want to do a little on one side then a little on the other so that it seats evenly. Then after the gasket is pulled through all the way around give the glass an open handed whack on the outside to seat the gasket in place.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
A little lubricant makes it easier.
Man does that sound like a real pain the backside! How hard is it to do a windshield?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
You would be amazed at how easy it actually is to do. Two guys that have done it before can do it in less than five minutes. It take more to explain than it does to do the job. Dishwashing liquid is a great lube for this and it rinses right off no mess.
