Old 06-13-2004, 05:27 PM   #1
Noah's65
Help with tie rod ends/disc brake conversion please
As I've mentioned before, I'm putting disc brakes on the front of my 65. I pirated the parts from a 71 gmc 1/2 ton. As I understood it, by swapping the ball joints and outer tie rod ends, these parts would fit. Here's the problem. My 65 tie rod ends are reverse/left hand thread and my 71 tie rod ends are standard/right hand thread. So what do I do about it? Do I need the 71 adjusting sleeve also? Help! Thanks, -Noah
Noah's65 is offline   Reply With Quote
Old 06-14-2004, 12:27 AM   #2
lngbed71
Nothing fits but the oil
lngbed71's Avatar
We worked demmit-hemmit's 65 burb with a conversion from salvaged 71 parts. If I remember right, the tie rod ends from the 65 fit the 71 spindle. Hemmit??
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 06-14-2004, 10:48 AM   #3
rodnok1
rodnok1's Avatar
I think they siad you use your old outers as inners when doing this conversion...
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 06-14-2004, 03:04 PM   #4
beaterC10
You will also need the 71 centerlink. I did this on my 63 and used 72 spindles and centerlink. I don't remember the exact combination of tie rod ends and sleeves I used, but it was all factory or replacment parts.
Sorry I can't provide more detail, but this was a few years ago and I have since parted ways with the truck.
beaterC10 is offline   Reply With Quote
Old 06-18-2004, 09:52 PM   #5
poolboy65-ls1
iamthepoolboy!
poolboy65-ls1's Avatar
You do use the outer as inners.
Black primed 81 Silverado SWB one owner rust free all original 106,000 project. Steel cowl hood, 89/91 front grill, Blazer tailgate trim, sport rear bumper, 5/6 Drop, 17" Eagle Alloys, Big block is on the stand! COMING SOON: one piece glass, and more.
poolboy65-ls1 is offline   Reply With Quote
Old 06-21-2004, 10:01 PM   #6
mrp
what are you going to do with your old parts?
mrp is offline   Reply With Quote
