Old 06-13-2004, 07:32 PM   #1
2tankin79
2tankin79's Avatar
K&N air filter
How tall is the tallest air filter K&N offers? i'm thinkin like 12'' round, but how tall? i've seen alot of really big tall ones that look really cool, but i cant find them anywhere??
Jeff
95 Z28, converter removed, flowmaster muffler, TB bypass, Forsale ---> K&N FIPK
1994 Pontiac Bonneville SSEi, totally stock
2tankin79 is offline   Reply With Quote
Old 06-13-2004, 08:25 PM   #2
cochran63
cochran63's Avatar
they guys at the local NAPA put a SEMI filter on top of the motor in his truck. That sucker was atleast 14 inches tall. My k&n filters are 14x4.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 06-13-2004, 08:26 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Im thinking 6 inch but Im not real sure if there is a taller one.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 06-13-2004, 08:31 PM   #4
ocbaud
Garage Queen Material
i've only seen the 6" ones for sale.
ocbaud is offline   Reply With Quote
Old 06-13-2004, 08:35 PM   #5
SanitysBane
while k&n's flow more air this is because they don't filter the smaller particles that a fram will filter out, plus u can never clean out a filter to a new state
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-13-2004, 10:11 PM   #6
cochran63
cochran63's Avatar
my question is : Just how much air does a naturaly aspirated small block need? i have the 4 inch filter with the extream top, but wouldn't a 2 inch element be plenty?
Old 06-13-2004, 10:15 PM   #7
cochran63
cochran63's Avatar
hey 2tankin79 you wouldnt happen to have some pics of your 327 would you? I would be interested in seeing how you mounted all your accessories without the bolt holes in the heads. The setup i had on my 327 worked but it was a pain in the butt.
Old 06-13-2004, 10:43 PM   #8
2tankin79
2tankin79's Avatar
It says they are all too big.. i dont have a/c on it.. and my alternator squeels because the belt is out of line.. i need the bracket that holds it on there.. i agree.. the 327 without the bolt holes in the head is a pain..
Thanks for all the replies.. i think the 6'' is the one i have seen.. lookin at it for a few minutes makes me believe its a lil too tall.. i dont like the look of the lil wimpy lookin ones.. I just like the looks of it.. i know a 4'' would be plenty..
Jeff
Old 06-13-2004, 11:11 PM   #9
cochran63
cochran63's Avatar
I had all the same problems on mine. When i transplanted the 327 into my 85 i switched to a serpentine setup. I got one from an early model chevy van. I think it was an 87. I used the 2 P/s hole and drill out the two on the exact oposite side of the p/s one and put a heli coil in them. Then i just put on from the bracket into the hole that is on the front of an edelbrock aluminum intake. I put some braces from the compressor and altonator down to the intake for some added support. I can get you come pictures if you like. I really like the setup.
Old 06-13-2004, 11:15 PM   #10
cochran63
cochran63's Avatar
I forgot to add that i was able to hook up the a/c with the serpentine setup.
Old 06-15-2004, 09:23 AM   #11
TwinTurbo
TwinTurbo's Avatar
I have a 12 ID (14OD) 6" tall filter too. Couldn't find a taller one.
..it's just the right size
TwinTurbo is offline   Reply With Quote
Old 06-15-2004, 02:14 PM   #12
Time Travel
Hey Twin,
That is one clean engine compartment!!!!!!
Time Travel is offline   Reply With Quote
Old 06-15-2004, 04:54 PM   #13
EricS76
EricS76's Avatar
I put a K&N on a 98 chevy at 230 miles, sold the truck with 102,000 miles. Never had any engine problems. I cleaned it twice during that time and it came out brand new both times. It probably was on dirt roads as much as paved, and I never had any problems due to poor filtration. I've had K&N's on 4 trucks, and I have one on my dodge diesel now. Never had any problems with anything related to the filter or filtration.
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop.
'77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
EricS76 is offline   Reply With Quote
Old 06-15-2004, 05:10 PM   #14
swervin ervin
You get what you pay for
swervin ervin's Avatar
What most folks don't know is K&N filters were designed for dirt track racing. I used to help a guy with his dirt track car and believe me, them things get dirty. Never did I see any dirt on the inside of the filter or air cleaner. They filter better than any stock paper element filter no matter who makes it. If you use the filter recharging kit that comes with cleaner and oil, it will clean up like new. Although, you don't need to clean them very often. You will not beat a K&N air filter.
I wouldn't run a Fram anything on my vehicles.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-15-2004, 05:12 PM   #15
SanitysBane
i run fram and have never had any problems with them, somethings its just a personal prefrence and how often u maintain it
'88 K5 Blazer
Old 06-15-2004, 05:51 PM   #16
TwinTurbo
TwinTurbo's Avatar
actually the K&Ns filter better once they get dirty (up to a point though, at some point they become downright restrictive). Testing revealed that a cheap paper element might flow a little more but filter less, a good paper will filter a tad better but flow less. A foam filter filled with oil is the best but only for short or track usage because they get brittle and you don't want chunks of them to be swallowed. K&N with the ability to re-oil has always appealed to me. It's the best of both worlds and the fact that dirty paper elements make the engine look like crap doesn't do it for me either.
Old 06-15-2004, 06:02 PM   #17
SanitysBane
i use a closed eliment air cleaner housing so no one knows what air filter i have
'88 K5 Blazer
Old 06-15-2004, 06:23 PM   #18
swervin ervin
Mine is hid too, but it has a K&N hiding in there.
Old 06-15-2004, 06:26 PM   #19
SanitysBane
wow thats a really good looking engine compartment, were did u get the ram air box from and for how much?
'88 K5 Blazer
Old 06-15-2004, 06:28 PM   #20
TwinTurbo
TwinTurbo's Avatar
http://www.ramairbox.com/
Old 06-15-2004, 06:55 PM   #21
MylilBowTie
Right turn Clyde
My engine bay needs some major attention (clean-repaint). I was going to get a 14x4 or so but summit didnt have any in stock at the time, I didnt want to wait so I got a 14x6. I also really really need some wire looms lol
Old 06-15-2004, 08:21 PM   #22
1980chevy4x4
Got Mud?
Is there an advantage to having a taller filter? And Is the K&N top that is a filter any good?
Dan
Got mud?
1980chevy4x4 is offline   Reply With Quote
Old 06-16-2004, 04:06 AM   #23
71-longbed
Its Magically Delicious
71-longbed's Avatar
i have a k&n hiding under my stock air cleaner..... 10k miles and it looks new .. i hope its filtering
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
