![]() Join Date: Feb 2003
I am going to buy a new set of plug wires and am trying to decide which boot style to get. I have a 68 SBC (the one in my signature line) with ram horn exhaust and it looks like straight boots would clear nicely. I will be using Morosco wire looms that bolt to the valve covers. Any pros or cons for the styles?
Thanks |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I perfer to use the wire's for a 75 corvette as they are really long and have straight boot's...
#3 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Fabricate till you "puke"
routed under , as in CPNE's pic is IMO much cleaner than over the top....a little more work to set up, but I ran the last couple with rams horns that way
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#5 | |
Resident Curmudgeon
![]() The only thing I've ever "fabricated" is the myth that I actually believe anything other than stock is wrong. ![]() Please note however, the engine is in the "correct" V8 position and my stock clutch linkage works very well. :p
#6 | |
MOVE OVER
No matter where you are..... There you are... Buckaroo Banzi |
"Ochre Ogre"
Ok, we all knew Jeff was a bubble off plumb, now we know he is also 90 degrees off too.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
#8 | |
Resident Curmudgeon
If you don't have HEI, then wires for the stock 67-72 SBC points ignition should work too, as they were designed to route in the same fashion. The 75 vette thing comes into play when you upgrade to HEI andwant to keep same routing as a 75 vette had HEI and ustilzed rams horn manifolds. ![]()
#9 | |
If you're gonna run headers, go with straight boots. Right now I have an HEI with straight boots on mine with stock exhaust manifolds, but I ordered a set of headers so I'm all set for 'em.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 06-14-2004 at 04:07 PM. |
most times the header tubes are in the way of using straight boots you will probably cook those straight boots and never be able to route your wires when you put the headers on you will see what im talkin about
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
I think I will be keeping the ramhorns for a while... I just ordered a set of straight boot wires. Thanks!
#13 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's a set of Accel's generic V8 HEI wires(straight boots)
I run 2.5" Corvette rams. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
