Old 06-14-2004, 11:23 AM   #1
atcavage
blinker won't blink
My right side turn signal won't blink. The back will light up, but I have to flip the switch to get it to blink. The front won't light at all. I checked the bulb, it was fine and it seemed to be making contact. The last time I had this problem I just took out the bulb and put it back in. When I was driving home my instrument lights died and I had to turn on the cab light to see them, and when I turned it off, the lights came on? Any ideas?
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 06-14-2004, 11:59 AM   #2
cdowns
cdowns's Avatar
bad grounds, make sure shiney metal to shiney metal for proper grounding
Old 06-14-2004, 12:44 PM   #3
thisolechevy
Yes definetly check the grounds and if the problem still persists try getting a new blinker relay (located on the fuse box) that could be bad, I recently replaced mine due to this problem.
thisolechevy is offline   Reply With Quote
