06-14-2004, 01:50 PM | #1 |
PROJECT 7DEUCE
Need door help!!!!
Can I weld some nut's on the back side of this lower door hinge mounting point the thread boss part is gone and the p.o. put nut's back there I was just wondring if I should try to find a new plate or just weld some nut's on there...
06-14-2004, 07:43 PM | #2 |
If that is the pillar area, you will want to get a plate for it and mount the plate so that it will move. If you weld nuts in there you won't have the adjustment that you need.
Tough job to do, Good luck! Jim |
