Need help badly
Ok heres the scoop i bought a 454 with a turbo 400 the problem i am having is driveline the turbo 400 has a bolt in spline and in order to use that i have to use a two pieace drive line but i have no where to mount a carrier bearing is there another option i need help badly and soon please
Thanks |
california fill
a bolt in spline? What do you mean by that? Is there a tailshaft on the th400? Are you saying that there is a yoke on the end of your transmission (that a U-joint fits into)??
If thats the case, you will just have to have a one peice driveshaft made with a slip-yoke in it somewhere. Is the truck a long bed or a shortbed? Even with it being a long bed, a one peice driveshaft (with the relatively long th400) should work fine. pc |
I had the same problem on the Burb I'm restoring now...
What I did : I used the front piece of a in two piece driveshaft coming from a C-10 LWB & let it lengthen & balanced by a specialist , so , I have now a one piece driveshaft , with the sliding yoke being connected to the rear axle , this is by the way what you can find on K5 Blazers ( and 4WD Burbs & trucks , I presume... ) I had no opportunity to test it , but I assume it will be strong enough to stand the torque of the engine the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents |
california fill
the baron--- just wondering, how's the interior on your '60? What about the ride, how's it ride??? <grin>
pc |
You get what you pay for
![]() Join Date: Dec 1999
1960 Girl Friend,frame still good,body has some dents
I never noticed this before. That's pretty good. I bet the girlfriend don't like it though. ![]()
Mike 1985 Chevy C-10 |
