View Poll Results: Truck of the month - June | |||
1970blazin | 21 | 34.43% | |
2wdBlazer | 11 | 18.03% | |
bouncytruck | 11 | 18.03% | |
FRENCHBLUE72 | 2 | 3.28% | |
jamie72 | 16 | 26.23% | |
Voters: 61. You may not vote on this poll |
06-14-2004, 11:52 PM | #1 |
Catchy title goes here..
67-72 Truck of the month June 04
Time to vote for Truck of The Month for June 04 . The following info was submitted by the nominees about their trucks.
Jamie72 General Manufacturer: Chevy Blazer Year: 1972 How long have you owned this truck?: 5 years History behind the truck: I saved this truck from the junkyard for $50. Chassis Suspension type: stock Front Brakes: disc Modifications: Rebuilt brake system Rear Brakes: stock Steering: power steering Front and rear tire/wheel type: 33-12.5-15 Trailblazers Front differential type / Gears: 3:73 Rear differential type / Gears: 3:73 Body Color Scheme: Flash Red Bodyman Modifications: Cowl Induction hood Paint Type: Martin single stage Painter: Us Interior Color: Black Material: Stock Upholsterer: GM Wiring: stock Modifications: Tilt steering, tach dash, CD player in Console Steering wheel/Column: Grant steering wheel on Tilt column Stereo/Speakers/Amps: Pioneer CD, Kicker speakers Air Conditioning: When the top is off! Instrument Gauges: Full gauges including tach Engine Cubic Inch: 350 Manufacturer: Chevy Camshaft:mild Cylinder heads: stock Valve Covers: Mickey Thompsons Intake Manifold: Edelbrock Ignition System: HEI Exhaust type: Dual Transmission Automatic / Standard: 4 speed Torque Converter: nope Modifications: stock Shifter type: stock Drive Shaft: Stock |
06-14-2004, 11:56 PM | #2 |
1970blazin
General Manufacturer: Chevrolet Year:1970 How long have you owned this truck?:Since March 2003 History behind the truck:Bought from the original owners son in Beaverton Oregon. The son told me that the Dad had ordered it new from the factory in 1969, but the factory went on strike, so his order didn't make it in until 1970. I have all the paperwork- handwritten of everything he EVER did to the truck including changing the headlight bulbs! Also have the Protecto- plate. The Orig. owner's son has kept in touch via email and we have sent him progress pics as we have done the restoration of the blazer. He came all the way from Hawaii to give us the original paperwork a few mounths after we bought the blazer and took pictures of all the work we had done. Chassis Suspension type:stock 4WD Front Brakes:drum Modificationsriginally a 307, but orig. owner had a GM crate 350 put in. Only 500 miles on that engine when we got it. Rear Brakes:drum Steeringower Front and rear tire/wheel type:Eagle alloy 15x10 w/ 31" TOYO AT tires Front differential type / Gearsana 44 - 373 Rear differential type / Gearsana 60 - 373 Body Color Scheme: Orig Dark Blue Poly Bodyman Modifications:fixed dent in rear drivers taillight area- repro. fenders (inner and outer) used doors, new GM grill (inner and outer), new repro smooth tailgate. Paint Type:Base coat/Clear coat Painter:Shawn's Custom Auto Interior Color: Black/Blue Material:Black vinyl and Blue/Black Houndstooth Upholsterer:A-1 Upholstery Wiring:Second fuse panel for power windows and stereo equipment. Modifications:Custom aluminum roll bar, 4 shoulder belts, Custom door panels and cargo panels (not done yet), Herculined entire floor and bed under carpet w/ sound deadner. A-1 electric power windows installed. Steering wheel/Column:woodgrain non-tilt Stereo/Speakers/Amps:Kenwood CD/MP3 player in glove box w/ (4) 6x9's,(2 in door and 2 in cargo panels) DVD player and tilt down 10.5" flat screen installed in the roll bar. Air Conditioning:No Instrument Gauges:Original gauges w/ original tach kit installed Engine Cubic Inch:350 Manufacturer: GM Camshaft:stock Cylinder heads:stock Valve Covers:stock Intake Manifold:stock Ignition Systemoints/coil Exhaust type:dual Transmission Automatic / Standard:Automatic turbo 350 rebuilt 500 miles ago Torque Converter:stock Modifications: stock Shifter type:stock Drive Shaft:stock |
06-14-2004, 11:59 PM | #3 |
FRENCHBLUE72
General Manufacturer:Chevrolet Year:1972 How long have you owned this truck?:4 year's History behind the truck:I have alway's wanted one and my wife found this for me evn though she hate's it... Chassis Suspension type:Stock leaf spring's Front Brakes:disk Modifications:rebuilt front and rear axle's along with t-case Rear Brakes:drum Steering:stock power Front and rear tire/wheel type:32x11.50 on 15x10 mod's Front differential type / Gears:3:73 Rear differential type / Gears:3:73 Body Color Scheme:white with a dirty pearl in the paint Bodyman Modifications:shaved emblem's Paint Typemni Painter:unknown Interior Color:green and parchment Material:vinal and cloth Upholsterer:dodge and G.M and metal floor's Wiring:Stock with sosche stereo wiring Modifications:Tilt Steering wheel/Column:classic three spoke design by grant Stereo/Speakers/Ampsioneer head unit -pioneer amp and explod sub's-6x9's and pioneer tweet's Air Conditioning:in the process Instrument Gauges:stock with summit add on's in the dash with a new chrome bezel Engine Cubic Inch:350 Manufacturer:G.M Camshaft:Crane Cylinder heads:stock Valve Covers:edelbrock Intake Manifold:weiand Ignition System:hei Exhaust type:headder's with turbo's Transmission Automatic / Standard:th350 Torque Converter:stock Modifications:shift kit and extra clutch pack's Shifter type:stock Drive Shaft:yep 2 of em |
06-15-2004, 12:01 AM | #4 |
2wdBlazer
General Manufacturer: Chevrolet (Blazer) Year: 1972 How long have you owned this truck?: 1 Year History behind the truck: Chassis Suspension type: 6 inch Leaf Lift Front Brakes: Disk Modifications: Rear Brakesrum Steering: Front and rear tire/wheel type: Bart wheels / Parnelli Jones Dirt Grips 38x15.50/15 Front differential type / Gears: D44/3:73 Rear differential type / Gears: Corp 14B FF/3:73 Body Color Scheme: Viper Race Yellow Bodyman Modifications: Stock Body Paint Type:Base Coat / Clear Coat Painter: Interior Color: Yellow / Black Material: Cloth 80's Volvo Seats Upholsterer: Wiring: Modifications: Steering wheel/Column: Grant Wheel / Non-tilt Stereo/Speakers/Amps: Pioneer CD/ 2 Blaupant 5x7's in dash / 2 Sony Explode 6x9's in doors / 2 Sony Explode 6x9's in rear. Air Conditioning: Yeah right! Instrument Gauges: Stock, No tach Engine Cubic Inch: 350 Manufacturer:Chevy Camshaft:NA Cylinder heads:Stock Valve Covers:Chrome Intake Manifold:Edelbrock Aluminum Ignition System: Stock Exhaust type: 2 1/2 Custom to Dynomax Ultraflows (Dual) Transmission Automatic / Standard: AUTO Torque Converter: Stock Modifications: NA Shifter type:Stock Drive Shaft: 3/4 ton stockers |
06-15-2004, 12:05 AM | #5 |
bouncytruck
Stats are; '72 350/TH350/NP205 - Bone stock! Chevy Red-Orange Parchment interior 16" wheels w/hubcaps Rust Free Original. |
