Old 06-15-2004, 12:07 AM   #1
LeRoy
Registered truck nut
LeRoy's Avatar
Ford 9" install
I've got a 9" to put in my 67 chevy with the coil sprung rear. I know some have done this. Well looking at it. It's looks like the axle shaft diameter increased from 3" to 3 1/4" about where you would mount the trailing arm. Since the U-bolt slips over the axle and into the trailing arm how does it work with the added 1/4"
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 06-15-2004, 01:37 AM   #2
1972C10
1972C10's Avatar
Id just notch the axle perches off the old rearend and enlarge them to fit the new one
I put a late model rachet locker out of a leafspring truck into my 68 Just get the perchs cleaned up and ready to weld then set the rearend onto them stab the u bolts and check it for sqaure i measured from the perch to the backer plate made that sqaure then measured from the front wheels to the back wheels and made sure that was the same then set the pinion angle at 4 degrees down rechecked everything then tack welded it tightend the u bolts let it down and re checked the pinion angle shouldnt change but i wanted to be sure it was the same on the ground as it was on the jack so i welded them for good
for the panhard bar i made a mount out of angle iron and welded it onto the rearend and got a longer bar off a 3/4 ton
You could use the entire set up panhard bar off a 3/4 ton Since they have a big bracket that welds on the tube instead of mounting on the housings like 12 bolts.
But you will need to get the bracket that rivets onto the truck as well since the angle for them are different .
1972C10 is offline   Reply With Quote
Old 06-15-2004, 04:02 AM   #3
LeRoy
LeRoy's Avatar
Thanks for the reply. The problem, I forsee, is that the holes in the trailing arms are 3" apart to fit the 12 bolt rearends 3" diameter. This 9" is a little bigger in diameter. You go and try and shove the U-bolt past the axle tube and it won't line up with the holes in the trailing arms. I know others have been here.
Old 06-15-2004, 07:48 AM   #4
crazy4chevs
crazy4chevs's Avatar
It shouldnt be a problem. Mine was the same way and it worked fine. If you have a spare U-bolt try it over the axle.
Oh.... I just remembered that my u-bolts were aftermarket, from ECE. They might be a little thinner than stock. Just try yours and see. I'll try to get pics.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 06-15-2004, 10:03 AM   #5
Bowtie468
Bowtie468's Avatar
LeRoy, I just put a 9" in mine and everything fits fine. Just grind the saddles a bit for the proper fit. My U-bolts fit the new axle tubes just fine. No probs there either . I'll also try to find a pic of mine.
Chris
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 06-15-2004, 10:22 AM   #6
Bowtie468
Bowtie468's Avatar
Here's the pic ! Those are also the stock u-bolts before i changed them.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 06-15-2004, 06:41 PM   #7
SCOTI
SCOTI's Avatar
Bowtie, what vehicle did your rearend come from? I know the Lincoln 9" rears were pretty similar as far as length . . ..... what else is close/same?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-15-2004, 09:11 PM   #8
1972C10
1972C10's Avatar
Bowtie 468 how is that cap held onto the rearend is it easy to take off or require tools?
Old 06-15-2004, 11:17 PM   #9
Bowtie468
Bowtie468's Avatar
SCOTI - This one came out of a '78 Ford Bronco. I did narrow it a few inches.
1972C10 - I merely installed this for a fill port. Its got a threaded steel bung that was welded to the housing. The cap is CNC milled from aluminum and simply installs hand tight. They are around 20 bucks from Jegs.
Chris
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
