Old 06-15-2004, 04:50 AM   #1
1986Silverado
What I drive
1986Silverado's Avatar
Going to a larger radiator....maybe
I am replacing my stock radiator which is the 29x19 core and was wondering if I went to one that was a 29x21 what would be required to install it....make it fit? Thanks
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 06-15-2004, 10:45 AM   #2
Prerunner1982
Prerunner1982's Avatar
i dont know the sizes but i assume you mean a 3core to a 4 core.... i just did this swap, you need the 4 (2 upper and 2 lower) insulators, and the mounting plate for the top. you will need a fan shroud if you plan on running one, the 3 core one wont work.
Prerunner1982 is offline   Reply With Quote
Old 06-15-2004, 02:03 PM   #3
1986Silverado
What I drive
The cores are still the same but I was told it was 2 inches taller than mine. Then I looked at lmc's catalog and they do not list one that is 21 inches tall....so maybe he measured it wrong.
2006 Chevy Equinox
Old 06-15-2004, 03:32 PM   #4
Prerunner1982
he may have been mistaken, you can get a 4 core from autozone for like $150. the insulators are like $4.00 each, and then the upper mounting plate... its really not a bad deal, and too easy to put in.
