06-15-2004, 07:59 AM | #1 |
Finally I Got a What Did You Get Done Thread
After watching everybody make posts showing off all the fine work they have done on their trucks I finally got off my butt and did something. This is a bare 350 block I pulled out of a 1971 Monte Carlo that the Minnesota road salt got the better of. It is currently at the machine shop. My plan is to make a 383 out of it for my truck.
According to the mortec site the "010" and "020" mean: "Some of the smallblock motors used blocks with an additional 1% tin and an additional 2% nickel added to the cast iron alloy. These very desirable blocks can be identified by looking at the block face under the timing chain cover for "010" and "020". These designators can also sometimes be found on the rear face of the block inside the perimeter of the bellhousing mating surface. " I hope the pictures attach. This is my first attempt with the "new" board.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
06-15-2004, 08:26 AM | #2 |
Good lookin' block... Minor core shift, but it should make a fine street motor for you. Good luck, keep the pics coming.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
06-15-2004, 09:15 AM | #3 |
PROJECT 7DEUCE
Congrat's on the progress..
06-15-2004, 09:29 AM | #4 |
MrGoodpliers...what is core shift?
06-15-2004, 10:46 AM | #5 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-15-2004, 11:14 AM | #6 |
When the block is cast, the molten metal is poured into a mold. Inside the mold are inserts that take up some of the space in the mold. This is so you get the openings inside the block, like the water jackets. There are plugs where the cylinder bores are too. (This cuts down on machining) These "cores" are made of sand and when the block has cooled and solidified the inner cores are broken and removed. That's why they are sand, it shatters into dust and flows out easily.
This internal cavity for water flow is why no one make "billet" blocks for automotive engines like they do for Harleys. Harley engines are air cooled and have only a few oil passages that are drilled in them. So, "core shift" is when the internal core pieces move out of perfect alignment before or as the motlen iron/aluminum is poured in. |
06-15-2004, 12:14 PM | #7 |
This is interesting.
Can you circle the spot in the pic that shows the shift? Thanks, Davy
1970 Blazer CST Looking for NOS items for my CST restoration. |
06-15-2004, 01:06 PM | #8 |
Look at the boss for the cam, and you will see that the hole is not exactly centered in the boss. This one is minor, if you are looking for a block to go all out with, stay away from one with a boss/bore that looks like a deviled egg!
06-15-2004, 01:26 PM | #9 | |
06-15-2004, 03:42 PM | #10 |
I have never heard that and I don't think it matters that much.
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed -1968 Chevy SWB = numbers matching 307/Truck 4 speed. -1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC -1972 Chevy Nova = 2 door/412 Small Block -1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything. |
