06-15-2004, 10:34 PM | #1 |
OK guy's. I need some serious help!
I am trying to install headers on my 72 Chevy truck.
The first set I bought was Dynomax part # 86003. Those hit the motor mount on the pass side. I could not bolt them up. So, I sent them back and ordered another set. I tried everthing even new tranny mount, and new motor mounts. The second set I bought were Hooker part #2552-1. Ceramic coated. I got the part # from Piston. He used these on his truck, and they fit great. These will not fit either. They are hitting on the upper control arm on BOTH sides. Has anyone else had as much problems installing headers? There are no signs of any frame damage or anything like that. Please help! Thanks, Nick |
06-15-2004, 10:44 PM | #2 |
Member since 2000
i wanna see how they are hitting your upper controlle arm. Can you post pictures?
06-15-2004, 10:52 PM | #3 |
Give me a minute...
06-15-2004, 10:55 PM | #4 |
PROJECT 7DEUCE
Are they fender well headder;s????
06-15-2004, 10:57 PM | #5 | |
Member since 2000
........anyone else hear Jepordy Music in the background |
06-15-2004, 10:58 PM | #6 |
PROJECT 7DEUCE
Yes alex I do I will take header's for small block chevy's for 300$
06-15-2004, 11:08 PM | #7 | |
Member since 2000
Small block Chevy for 300. "What do you call a pre-assembled motor that comes with everything except the carb and headers" |
06-15-2004, 11:12 PM | #8 |
here it is. My mistake, it is hitting the lower control arm.
06-15-2004, 11:15 PM | #9 |
Your engine towers are in the wrong holes.
06-15-2004, 11:16 PM | #10 |
PROJECT 7DEUCE
Long block could also be a crate motor
06-15-2004, 11:18 PM | #11 | |
???Can you explain this please??? |
06-15-2004, 11:18 PM | #12 |
Fabricate till you "puke"
i have hookers on my longhorn.....can you take a pic from the top(eng mounts/stands)?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-15-2004, 11:22 PM | #13 | |
06-15-2004, 11:24 PM | #14 | |
Member since 2000
but... judges...........we'll take that anwser. Congrats! n737- have you thought about some chevelle shorty headers? I know some members had to do some custom work on the righthand frame rail but most go in with-out any trouble. |
06-15-2004, 11:24 PM | #15 | |
06-15-2004, 11:28 PM | #16 | |
CRAP! Your kidding me. |
06-15-2004, 11:35 PM | #17 |
love my truck
you can alwayse buy shorty headders
06-15-2004, 11:36 PM | #18 |
interesting, ive got dynomax headers i bought from autozone last year and the fit great. my v8 is mounted in the correct v8 position which are closer to thr radiater.
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE |
06-15-2004, 11:38 PM | #19 |
I am running 2452 Hookers(painted). My eng is in I 6 position, which slides it back about 3 1/2" from factory V8 sb spot. Looking at mine, it does look like the headers would fit d@mn tight in factory position.....they were built to fit a V8 truck tho.....? if you need just a little clearance, you might try loosening the bolts in the eng stands , & also trans crossmember, & sliding the eng back just a tad....the headers should fit that truck(should is a big word at times tho!) crazyL another thought.....you might check to see that the lower control arm shafts are properly located in the saddles(front to back). There is a locator pin on on end, that sits into a hole on the shaft. If someone had it apart @ 1 time, the shafts/arms could be moved rearward? best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 06-15-2004 at 11:45 PM. |
06-16-2004, 09:20 AM | #20 |
So which mounting holes are the correct ones for a V8, the forward or the rear?
Is it going to hurt me in ANY way to move this engine/tranny to the rear mounting holes? Thanks for everyones help! Nick |
06-16-2004, 09:37 AM | #21 | |
Resident Curmudgeon
If you're not building a performance engine (read stock to mild build), a good set of rams horns will work (and fit ) and alieviate a ton of potential headaches as well. The doctor sez: "Take to rams horns, and call me in the morning".
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
06-16-2004, 09:40 AM | #22 | |
Resident Curmudgeon
06-16-2004, 09:54 AM | #23 |
If you loosen the stands, you should find a little adjustment(in stock position). if all you need to gain is say approx 1/4" for clearance, you may need to drill , or slot the trans crossmember (center holes for the mount), & it wont cause any fitment issues on the driveline or anywhere else.....I agree with CPNE, i would leave it in stock position , as its aready to run. IMO, i would check the a arms 1st, & adjust as needed from there(minor adjust on the stands). crazyL
06-16-2004, 11:33 AM | #24 |
Try shorty headers or hone out some manifolds before you re-engineer the whole deal!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
06-16-2004, 11:43 AM | #25 |
I am just going to reinstall the stock manifolds, and get the exhaust routed. Then this winter, I will worry about all of this.
Thank you for all of the responses, and ideaas to help me out. Nick |
