06-16-2004, 09:23 AM | #1 |
Prestige Worldwide
Big Block parts for sale
I have a whole set of brackets and pullies for our trucks to use the short water pump. This also includes all A/C brackets, and even a power steering pump. I also have a set of 68-71 bog block frame stands that are bramd new from GM and a set of engine mounts (rubbers) as well.
$500.00 Jason jrs3498@aol.com 770-389-7785 |
06-16-2004, 09:24 AM | #2 |
Prestige Worldwide
how about them bog block parts huh.....
I meant to say big block but I am sure you guys caught that. Jason |
06-16-2004, 12:58 PM | #3 |
Do you have a heat stove and the tube that goes to the air cleaner. If you do I will take them.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
06-16-2004, 03:47 PM | #4 |
What do you want for just the 68-71 bog block frame stands?
06-17-2004, 12:03 AM | #5 |
"Trucks with Class"
Just want to clarify, are the rubber mounts also NEW GM?...or just the frame stands?
06-23-2004, 09:15 AM | #6 |
Prestige Worldwide
The frame stands and the rubber mounts are both new from GM. I got lucky and ran some down through a dealership. I ended up paying about $275 or so for the mounts and stands. I would consider an offer if you guys want to make one.
Jason jrs3498@aol.com |
