Old 06-16-2004, 01:06 PM   #1
1-PU70
1-PU70's Avatar
Antenna Wire Into Cab Seal
What do you guys use to seal the cab where the antenna wire comes in?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 06-16-2004, 01:25 PM   #2
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
PU70,
If it's a pretty tight fit, I've found hot glue to work well and last the longest. If the hole is quite a bit larger, silicone will stay in place where the hot glue won't.
If you go the glue gun route, get some high strength glue sticks, not the cheapo craft kind. I've seen the stuff hold paint pretty well, too.
SSOW
stickshift_or_walk is offline   Reply With Quote
