Old 06-16-2004, 09:07 PM   #1
swervin ervin
You get what you pay for
swervin ervin's Avatar
What'cha think?
Stainless Steel Brakes, front brake upgrade. Now I have to get some new brake hoses. My stock rubber won't work.
I guess I'll go ahead and get some stainless hoses from Inline Tube. Now I still have to wait to get my brakes done.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-16-2004, 09:13 PM   #2
ocbaud
Garage Queen Material
i think i like it.
ocbaud is offline   Reply With Quote
Old 06-16-2004, 09:40 PM   #3
SanitysBane
what do u do when u need new pads? does it use the factory size?
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-16-2004, 09:43 PM   #4
bigblock73
yeller
bigblock73's Avatar
Looks awesome Mike!
Come do mine now.
bigblock73 is offline   Reply With Quote
Old 06-16-2004, 09:48 PM   #5
swervin ervin
Yes, it uses the same pads as my stock ones. My truck came with JB5 brakes which is part of the 1-1/4" rotors.
Jeff,
I'll be there after while.
Old 06-16-2004, 09:51 PM   #6
ocbaud
if i wanted to upgrade my brakes, i would need new spindles, rotors, and calipers?
Old 06-16-2004, 09:57 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Mike what exactly is that? Is that the SSBC slotted rotors and your repainted calipers, or did you get something more?
I'm thinking about swapping my SSBC from my Blazer to the 77. I can't make up my mind if I want that or build a bigger brake system. Regardless that looks good....
Stick a wheel on so I can see what it looks like
Old 06-16-2004, 09:57 PM   #8
swervin ervin
Do you have 1-1/4" rotors now? If not, yes, you would need new spindles.
Mike
1985 Chevy C-10
Old 06-16-2004, 09:56 PM   #9
SanitysBane
do the bear kits use the factory style pads too?
'88 K5 Blazer
Old 06-17-2004, 08:30 AM   #10
7T7
Regular guy
7T7's Avatar
The Baer kit I have uses 97-up Corvette pads.
Swervin, The wheel on pic did it!
That looks TRICK!
7T7 is offline   Reply With Quote
Old 06-16-2004, 10:00 PM   #11
swervin ervin
Ken,
it's this.
http://www.ssbrakes.com/products/det...D%29&year=1985
I bought it from Summit and saved $45.00.
Edit. I forgot to add. I had to wait 3 weeks though.
Old 06-16-2004, 10:03 PM   #12
ocbaud
Originally Posted by swervin ervin
Ken,
it's this.
i have to get new spindles anyway.
so i might as well get the heavy duty ones and get that kit
Old 06-16-2004, 10:05 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
So the rotors are the same size, it just uses "larger than stock" calipers? Are they GM calipers or what?
Old 06-16-2004, 10:19 PM   #14
swervin ervin
Ken,
to tell you the truth, they look almost like my stock calipers did. The piston is bigger though. They use the same pads I do know for sure. I didn't look at them real close, but I don't think they are GM made. I didn't see any GM markings on them. What I like is they are new and not rebuilt. The kit comes with new everything.
Old 06-16-2004, 10:24 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
OH YEAH!!!!! That looks sweet Mike. I wonder if I could just order the calipers. I already have everything else...
Old 06-16-2004, 10:35 PM   #16
SanitysBane
if i only had the money...
'88 K5 Blazer
Old 06-16-2004, 10:49 PM   #17
swervin ervin
Ken,
I searched their site. Didn't see calipers like mine by themselves. Did find these though.
Give them a call and see what they say.
Old 06-16-2004, 11:29 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for the link Mike. That looks like a perfect upgrade since I already have the rotors. Now I need to decide what to do about the rear. I have a disc conversion already, but it uses Ford style calipers. I like the new kit they have with the PBR style calipers better. ...
Old 06-17-2004, 12:01 AM   #19
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Looks really good
Question: Where do you get new spindals for the 1 1/4 in rotors?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 06-17-2004, 12:23 AM   #20
PHOENIX
Looks sweet Mike!
How do you know if you have heavy duty brakes or standard duty brakes?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-17-2004, 12:51 AM   #21
BaggedC10
Under construction!
BaggedC10's Avatar
Looks awesome, Mike. I'll be buying this kit soon too. Do you think the "Xtra Life" rotor plating is worth the money?
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 06-17-2004, 01:04 AM   #22
swervin ervin
For spindles, you can buy stock ones, or they sell 2" drop spindles in kits with this brake kit. I have two stock height 1-1/4" spindles in the shop that come off my truck.
Heavy duty brakes they are referring to is if your rotors are 1-1/4" thick.
I don't know about the xtra life plating. I didn't get it. What is it exactly? Something to keep them shiney or make them last longer? I'm going to buy some caliper paint from Eastwood and paint everything on the rotors that the pads don't rub. Thinking maybe gloss black to match the calipers. Anyone ever used any of this stuff. The kit to paint 4 calipers is $35 bucks. Of course I'll be painting rotors instead.
Old 06-17-2004, 01:11 AM   #23
BaggedC10
Under construction!
BaggedC10's Avatar
Xtra Life Plating
If you upgrade to the Turbo slotting, you can then also add our Xtra Life plating. In this process we add protective finish layers to the entire surface of the rotor. This will help prevent the areas where the pads do not come into contact with the rotor from rust and corrosion, all while maintaining that “new” look.
I have the Eastwood caliper/drum paint kit and it includes everything you need. I haven't used it yet but if it's like the rest of their products.....I'll be happy.
Old 06-17-2004, 09:03 AM   #24
bluex
bluex's Avatar
Looks good man! I've really got to stop hanging out here, I'm going to be broke!!
What size are your wheels? I'm just wondering if you can run 15" wheels what that setup.
bluex is offline   Reply With Quote
Old 06-17-2004, 10:53 AM   #25
arveetek
Ultimate Diesel Dude
arveetek's Avatar
Mike,
Did you ever get your rear disc problems sorted out? I never did read if you got the squishy pedal fixed.
Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
