Almost done!
Dome Light Upgrade
A friend at work was telling me about seeing where someone upgraded their dome light to one with a dome and two map lights. Anyone have any information on the swap?
Thanks...Kelly
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill Last edited by MACKL; 06-16-2004 at 10:33 PM. |
My truck had that. the guy i bought it from put it in. but the map lights didn't work and the base of it was made out of ply wood. It looked pretty ugly.
I just removed it and put an original back in. What it looked like on his install was he just soldered the original dome light wires to the assembly and a jumper wire to the map lights so when it was switched on the lights they would get power. but i guess the bulbs were burnt out or something. Hoped this helped a little at least.
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
the truck I drive at work ('96 Chevy C/3500 dump) has a dome lite with 2 integrated map lights in it. it looks stock to me.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
I found one in the JC Whitney catalog for about $15. I have not ordered one yet.
Silence is golden, duct tape is silver. - Scott |
Almost done!
TTT. Surely someone knows something!
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
Keep On Truckin'
I have looked and looked and looked with no luck so I finally gave up. If you want to cut the hump out then probably something could be made to work.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
