Old 06-16-2004, 09:32 PM   #1
pritch
pritch's Avatar
Are these frames the same?
I'm going to start work on my '68 panel. I want to get a frame first, and get it all ready, and then switch the body over. A guy gave me a frame off a '72 1/2 ton. Is everything the same or will I have to do any mods? I want to switch to an auto trans, and this donor has a four speed, so I know I'll have to switch cross members. Anything else you guys can think of?
pritch is offline   Reply With Quote
Old 06-16-2004, 09:40 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
If it is a 1/2 ton pickup it will be different. If it is Suburban it will be the same. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-16-2004, 10:24 PM   #3
pritch
pritch's Avatar
Ya- the '72 is a pick-up. What's diferent between them?
Old 06-16-2004, 11:18 PM   #4
Rod
Rear Cab mounts are different... you'll have to switch them to the other frame.
The brackets on the top of the frame to mount the box or in your case a suburban body are specific to each owns application... so you'll have to switch the mounting brackets on the back part of the frame pretty much back from the rear cab mounts backwards.
The truck frame will be shorter than the suburban frame in overall length. Suburban frames are longer as the rear part of a sub / panel frame is the mounting point for the rear bumper.
Then are there difference in the rear suspensions... you have leafs on the truck frame? Coils on the sub/panel? If not and there both the same type then it should work.
I take it there both 2 wd.
A frame brackets for the trans linkage for an automatic you'll need off of the automatics frame.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-17-2004, 09:44 PM   #5
pritch
pritch's Avatar
The donor truck has coil springs and is two wheel drive. So other than changing the body mounts and adding the proper x-members for an auto trans., it is do-able? How much shorter would the pick-up frame be? That is one reason I want a new frame, because a P/O cut the rear end of the panel's frame off with a torch, I suppose to remove the bumper
(Dude-if ya got a torch in your hand, just cut the bolts!)
Old 06-17-2004, 11:32 PM   #6
Rod
Its just the back end lengths of the frame rails thats shorter. Maybe 4 inches.... never really bothered to measure...myself... I have both I guess I should one day.
I guess it depends on what type of rear bumper you want to use... if you want a rear sport bumper style then thats what the original frame lenght of the suburban frame was made for.... mind you ... you have both frames... you could cut the difference off the older sbuburban frame and put it on the truck frame and you;'ll get the right lenght you'll need anyway. If no welder you could still cut it off and use a inner metal plate to put it together.
Whoopes re-read PO cut back off.
Ok I guess it depends on the bumper you want to use on the back.
Might be a member with a frame to chop up for the pieces if you need them, or make your own brackets that extend to the lenght you need.
Old 06-18-2004, 11:25 PM   #7
pritch
pritch's Avatar
Thanks, Rod. I just thought of something-I have a '67 truck bed trailer that wouldn't miss the last few inches of it's frame at all, and I'm a fair welder, so I think this just might be what direction I'll go.
Old 06-19-2004, 10:41 AM   #8
da-burb
"Ochre Ogre"
da-burb's Avatar
I can't tell what part of the country your are from, but if you happen to be in the midwest, I have a real nice Texas rolling suburban frame in my shed. I'll have another one after I do a body swap onto my K10 burb too. Plus I have 2 parts burbs that i would like to sell this year too. Need a frame by any chance??
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-19-2004, 10:51 PM   #9
pritch
pritch's Avatar
Da-Burb, I am in Utah, so thats quite a ways to go. Thanks for the offer, though. I think I'll go with this donor truck that was given me, can't beat the price and it's only 3 miles from my house. There will be a lot of parts I won't be able to use off it-all the guy wants back is the cab-so after I get it all stripped I'll see what's worth getting rid of.
