Old 06-17-2004, 12:54 AM   #1
ANSLEY
need front end for 90 GMC burb
wanted - a front end for a 90 up GMC burb or blazer ''four head light'' need front radiator support complete grille and wiring . I am converting my 83 truck to a newer front end . b_1low67@yahoo.com
ANSLEY is offline   Reply With Quote
Old 06-29-2004, 03:59 AM   #2
balps
Hi Ansley,
Can't help you with the front end itself, but if going to the four headlight setup, be sure to wire the lights so that you have all four lights for high beams...big difference!
There's kits available to modify a factory four headlight system to do this, but with your conversion, you should be able to wire up an extra relay, etc, to get the final result.
Good luck
John
'90 Suburban 2500 - 383 TBI - built TH400
'99 Sierra Pickup - 327 MPI
balps is offline   Reply With Quote
