Old 06-17-2004, 09:29 AM   #1
dubie
dubie's Avatar
Got the engine timed
I timed the engine last night to 8 degrees above TDC. Then pulled the plugs, cleaned them and re-installed. I had 4 black ended plugs after all the cranking it took to start the pig.
Now that it's all done, it runs great and idles smooth, but................I have another question
When I throttle it up I have a very small burst of white smoke come out of the top of the carb. Is this normal?? ALso it pops when i let off the gas but i figure thats because I have no exhaust on the thing and have no back pressure.
Any ideas guys?
You guys have been so great in helping me out and I thank everyone of you!!
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-17-2004, 09:34 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Finally she's running congrat's.... The small pop's it make's when letting off the gas is from no exhaust no big deal but I would get exhaust on it soon... I am not sure on the white smoke or is it a mist from the carb? Glad you finally got her running .....
Old 06-17-2004, 09:41 AM   #3
smokekiki
Mike
smokekiki's Avatar
Put your exhaust on there,and try giving it a few more degrees on the timeing.My blazer runs best with 12 btdc,and my suburban at 10 btdc.I think I saw where You have HEI?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 06-17-2004, 09:42 AM   #4
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Glad it's runnin' smooth Bud!
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 06-17-2004, 09:44 AM   #5
dubie
dubie's Avatar
yeah, now I gotta get the rest of the MUTT together so I can drive it to the exhaust shop next week
Old 06-17-2004, 11:50 AM   #6
thisolechevy
My Edelbrock carb does the same exact thing, when you give it the go go juice she spits a little white smog but it is normal, it means power!! well thats my theory anyways.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 06-17-2004, 07:17 PM   #7
GMan69
GMan69's Avatar
Man, I know you're relieved, especially with all you went through to get it started. Now you're ready to ROCK.
George
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 06-17-2004, 07:31 PM   #8
crazy longhorn
Fabricate till you "puke"
It sounds like you have got it on the run Dubie I agree with smokekiki, play with the timing to find the "sweet spot". i have seen the same stuff, some run better with a little less timing , & some like a little more.....every combo is different. just listen to what that little chev wants....& give it to her! best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-17-2004, 10:02 PM   #9
71 Blazer CST man
71 Blazer CST man's Avatar
thisolechevy - hahah i like your theory, i have lots on certain "things" and noises my truck makes....most of them resulting it "yep, must mean lots of power" heh heh heh.
71 Blazer CST man is offline   Reply With Quote
Old 06-17-2004, 11:27 PM   #10
Randy70C-10
Randy70C-10's Avatar
Randy70C-10 is offline   Reply With Quote
Old 06-18-2004, 12:41 AM   #11
67cst
i love summertime
67cst's Avatar
man i need to learn this stuff too, i wish i had you guys as neighbours, talking about getting things just right...sounds coool...i just get it driveable, imagine the possibilities
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 06-18-2004, 09:22 AM   #12
dubie
dubie's Avatar
I'm just learning as I go bud I actually kearned how to time the engine from Horsepower TV believe it or not I watched them do a cam swap on an old nomad station wagon and then they showed how to time it with a light. It's so damn easy that it only took me 2 minutes and it was done. Just keep asking questions, even if you think they may seem stupid, ask anything. Thats the only way to learn
Thanks for all the great comments guys
Old 06-18-2004, 09:53 AM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
Hmmm, did you also learn how to make stupid plays on words, those guys kill me, I'm half tempted to watch it with the volume off, but they do seem to be getting better lately.
Still, rather have them making their stupid comments rather than have no show at all. The do some pretty fun projects.
Glad you've got the timing all set - I will be doing that one of these days if the planets all align and luck is on my side.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
