06-17-2004, 11:08 AM | #1 |
Is the Front suspension off a 71 different than the 73-87??
I have a 80 burb parts truck and a 71 GMC frame I am going to shorten. Is it worth changing the complete front suspension from the 71 to the 80?? Cheaper parts,better susp??
Thanks.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
06-17-2004, 11:18 AM | #2 |
They went to rubber bushings on the a-arms in 73
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
06-17-2004, 11:47 AM | #3 | |
06-17-2004, 04:24 PM | #4 |
Watch out for your cornhole !
No, they MIGHT ride a teeny tiny bit better, but you probably won't even notice. It was GMs way of (a) cutting a little of harshness out of the ride of the truck and (b) making 8 less places to have to grease on the newer trucks.
For my money, I'd continue to use the 71 stuff. It should already have disc brakes, being a 71, so there is nothing really to gain by changing the parts to newer ones.
06-17-2004, 04:32 PM | #5 |
It does have disc brakes. I'll just shorten the 71 frame and keep all the 71 suspension then. Thanks!!
Will the 80 spindles fit on the 71??
06-17-2004, 04:56 PM | #6 |
if you use the 80 model ball joints and tie rod ends.
06-17-2004, 05:03 PM | #7 |
So 80 model ball joints will fit in the 71 control arms??
06-17-2004, 05:28 PM | #8 |
yep, they install just like the stockers.
I can't remeber, but it seems like the 71 lower one is the same as the later years used. Seems like the upper one is the one that needs changed. Check a parts book to be sure.
06-17-2004, 05:43 PM | #9 |
Thanks for your help.
I just ordered 3" drop spindles for the 71 suspension,4" coils for the rear and a set of shocks all the way around.
06-17-2004, 06:50 PM | #10 | |
CCRider
From my experience....the rubber bushings do ride better on trucks that are lowered with cut/shorter springs...not much difference with stock springs
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
06-18-2004, 11:13 AM | #11 |
I ordered the Belltech 3" dropped spindle,so I'm still going to be using the stock coil.
