06-17-2004, 07:19 PM | #1 |
Header Advice Please
I have bought a set of dynomax headers and I noticed the tubes look dangerously close to the plugs ie: burnt wires look to be in my future. I have always run manifolds on all of my toys until this project for some reason ,so I dont have alot of experience with headers. Is it the headers meaning did I buy a cheap set or is this common for these trucks and if so what are some solutions like high temp wires header wrap etc. What have you guys experienced?
67' Chevy C10 Lwb small rear window 71' Gmc 1500 custom 4x4 72' Gmc Grande Sierra |
06-17-2004, 07:31 PM | #2 |
Use shorty plugs and you can gain some clearance. I am going to install plug wire insulators from Summit beacuse I just burnt through another wire(read expensive) and I am using shorty plugs already.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
06-17-2004, 07:40 PM | #3 |
Fabricate till you "puke"
Yup, high temp wires & shorty plugs! i cant say from experience on the dynomax headers, but I have run Hedman, & Hooker with very little problems.....once in a while, I do have a plug boot split from the heat(what the he!! , its a hotrod!). Some of the best wires I have run are MSD spiral core. They seem to hold up to the heat pretty well. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-17-2004, 08:05 PM | #4 |
ceramic-coated headers fry less wires because they'll run cooler
06-17-2004, 09:08 PM | #5 |
im running dynomax headers and yes they are tight and look like they wont fit but i run autolite 25 plugs and taylor wires havent burnt one yet
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
