Old 06-17-2004, 10:54 PM   #1
jcueckert13
jcueckert13's Avatar
choke on stock engine???
how was the choke hooked up on out trucks? today after having the truck die i took the carb off and found the choke was not hooked up. i also cant tell where it was suppost to connect. the carb(q-jet) was not origional and had a threaded connector that went in to the choke. right now i am putting a holley on and it has a electric choke so what do i hook the + terminal on the choke to?
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 06-17-2004, 11:00 PM   #2
jcueckert13
by the way i also have three wires on the pass side of the engine compartment one is the temp sending unit and the other 2 come in to a 2 flat prong connection. these wires go nowhere right now but would the 2 prong be the choke by chance
1976 Dodge Dart
1963 Dodge Dart
Old 06-18-2004, 07:33 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
are those wires green? may be for the AC clutch coil. one came from the dash & the other goes to ground.
as for the choke wiring. find the empty male spade terminal in fuse block labeled "IGN" & run from there to red + lead on choke. black - goes to good ground like choke cover screw. make sure ground is less than 1 ohm between wire & batt or choke will be closed longer than needed. general rule of thumb is you have 0.2 ohms per connection.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-18-2004, 07:56 AM   #4
Tynee
I miss this truck.
Tynee's Avatar
So when I hooked my choke wire directly to the coil, is that going to cause me problems?
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 06-18-2004, 11:58 AM   #5
jcueckert13
the 2 wires i was refering to are black and blue and they come out of the same harness as the temp sending unit. i dont think it would have anything to do with the ac because the truck is a non/ac truck
1976 Dodge Dart
1963 Dodge Dart
Old 06-18-2004, 04:53 PM   #6
jcueckert13
ttt. any body know how the choke was origionaly setup on these trucks
1976 Dodge Dart
1963 Dodge Dart
Old 06-18-2004, 05:54 PM   #7
john
member #16
john's Avatar
There is a thermostatic spring under the tin cover that connects to the choke with a rod. (see pic) Then the newer ones had a tube from exhaust manifold to choke, then they used electric on the later ones. John
john is offline   Reply With Quote
Old 06-18-2004, 06:25 PM   #8
nu2-72
John, very nice engine compartment. Can you get a close up pic of the choke setup as it connects to the carb?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 06-18-2004, 07:31 PM   #9
jcueckert13
thank you for the help. i am not going with the stock setup so i dont need a close up of it i was just wondering what to look for to see if my truck still had it.
1976 Dodge Dart
1963 Dodge Dart
Old 06-18-2004, 07:47 PM   #10
john
member #16
john's Avatar
nu2-72 Heres a close up.
Old 06-18-2004, 11:02 PM   #11
nu2-72
The closeup was for me. Thank you John.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
