Member #1049
WTB: early One piece dually wheels
Anybody in the Seattle area have 4 extra one piece 16" dually wheels with the 1/2 stud holes.. Not a good combination....
I have the later 71 - 72 wheels with the 5/8 hole and I have 1/2 studs.. the next option is 71 - 72 1 ton hubs with the correct studs and lug nuts.. would rather not dissasemble it to change hubs and studs.. wheels would be so much easier.. Anyone???? |
![]() Join Date: Mar 2003
The 1/2'' hole rims are split rim I believe, and require a tube.
Member #1049
I have one piece 1/2" ones on the front with tubes.. So I do know they exist.. but finding more might be another story..
![]() Join Date: Aug 2001
![]() MY 69 1 TON TOWTRUCK HAD SPLITS ON THE DUEL WHEELS IN THE REAR, BUT SOLID 1 PIECE WHEELS ON THE FRONT. I REPLACED THE 1/2" STUDS ON THE REAR WITH 5/8" STUDS SO I COULD USE MODERN 1 PIECE WHEELS. ![]() ![]() ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I had splits all around on my 69. Changed them all around when I went to disc and a D70.
Edit---try this 1-800- USED RIM They are in L.A. |
