Old 06-18-2004, 11:18 AM   #1
KP1972
KP1972's Avatar
Filler neck gasket
I need a fuel filler neck gasket for my 72 truck that has a longer flexible "rib/lip" at the top. I ordered the "correct" one (kind of a hard rubber with a little flange on the base) which just won't work on my truck.
Check out the photos. I need a gasket like the one I had to cut off (in pic)
1972 Chevy Custom/10
www.PictureTrail.com/KP1972
Metroplex Muscle Car Club
www.PictureTrail.com/DreamCarArt
KP1972 is offline   Reply With Quote
Old 06-18-2004, 11:50 AM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Looks like the standard 1 1/2" gas filler grommet to me. Did what you recieved have a 2" I.D.? If so it isn't the correct one for the tank that you have. We have several of each in stock. (Genuine GM) Here is a picture of the two different styles.
WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-18-2004, 12:14 PM   #3
KP1972
KP1972's Avatar
WES-
the one in the left photo looks like the one that fit. I just went and measured the width of the actual filler neck and it measures 2 1/4".
The NEW one that won't fit came from LMC.....it is "stamped" in the rubber.
The OLD one has no ID markings at all.
Old 06-18-2004, 12:37 PM   #4
Classic Heartbeat
The grommets that you get from LMC are junk. They are the ones made in India and even if you get them to fit, they crack within the first year. When you measure the filler neck you need to measure it below the spout. Measure the tube itself just above the tank. That is what the grommet seals against. The 71-72 trucks, unless the tank has been changed, use the 1 1/2" grommet. We have plenty in stock if you need one. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 06-18-2004, 01:39 PM   #5
KP1972
KP1972's Avatar
I replaced the gas tank (the old one rusted) and the neck is DEFINITELY 2 inches.
This old truck was pieced together when I got it, but I like it anyway!
Old 06-18-2004, 02:32 PM   #6
Classic Heartbeat
Just about all of the trucks out here are put together from a couple of different trucks. The O.D. of the filler neck itself will be larger that 1 1/2" because it will need to stretch the grommet a little to be able to seal it. What is the I.D. of the grommet you have?
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 06-18-2004, 03:33 PM   #7
KP1972
KP1972's Avatar
the old one cracked in multiple places around the lip of the interior diameter, and then I had to cut it to get it off. If there is NO such thing as a 2", I guess I will have to hope that a 1 1/2" will stretch. One of the hangups in installing the last one it the the filler neck angled up so high from the cab hole.....you probably can see it in the picture.
