![]() Join Date: Dec 1999
changing body mounts?
are your body mount bolts welded to your body as well? if so how do we switch out the bushings without completely lifting the body?
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Your body bolt's should not be welded to the body if so I would cut off the head of the bolt and replace the bolt's when you replace the bushing's..
Finally something I can comment on. I just finished replacing the body mounts in my 72. Yes each bolt has a spot weld to help secure the bolt. I took a cut-off wheel and cut the heads like pizza and used a cold chisel to break them off. The ones in the floorboards are sunken (sp?) in recessess. I used a cut-off wheel and tried to make a cross that went through the middle, and then used a large drill bit to drill the head of the bolt off. I ended up having to use the chisel to finish the break of the head. I used a grinding stone on the end of a die grinder to clean off the spot weld.
I did one side at a time. I used a floor jack and some pieces of 2 x 6 (to spread the weight) and lifted each side of the body. It really wasn't that bad of a job. I got the mount kit from Tim Christian and it was perfect. I would suggest getting a very good quality drill bit for the bolts going through the floorboard.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
![]() Join Date: Feb 2001
Yes, the body bolt heads are tack welded to the floor from the factory. You can grind them, although the recessed ones can be tough to get at with a grinder.
'72 Chevy Blazer |
You beat me to it NuBomb.
'72 Chevy Blazer |
and this is definitely easier than lifting the body, what would it be, 8 inches? right? you should know that i just put in the engine and tranny and havent put the fenders back on yet
I appreciate the input
Mine were tack welded to the floor too. I just center punched the bolt heads and drilled through them... used a 1/4" punch to drive the bolts down through the mounts and an air chisel to knock the heads off.
