Swap TH350C for 700R4? ?
Have 350C - Lockup Converter will not lock in. Thinking of exchanging with 700R4. Any thoughts on this..
Looking for what this might cost.... |
Professional Grade
Ok, as far as I know you'll need to move the transmission crossmember back a couple of inches, install a TV cable setup, and possibly get a new driveshaft depending on how long of a tailshaft you have on your current TH350... Not sure about costs, or if I am missing anything here...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
You'll also need to address locking and unlocking under braking, pretty simple. I also heard of a low vacuum setup as well.
You'll also need to address locking and unlocking under braking, pretty simple. I also heard of a low vacuum setup as well. try going here:
http://www.73-87.com/7387garage/drivetrain/lockup.htm |
I had a 350C and went to a 700R4 had to shorten driveshaft. Love having the overdrive in the transmission help gas mileage alot
