Old 06-18-2004, 10:51 PM   #1
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
Question How hard is it to change a windshield on a 60-63??
For an average joe like me to change a 60-63 windshield at home? Is it really tricky because of the wrap around or easy? thanks.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
Old 06-20-2004, 12:15 AM   #2
Lgriffin
I can't answer all of your question. I've only removed 2 63 window shields so far. The first I broke. I'd cut the old off of the outside of the window. I thought I was carefully lifting the window out of the seal and it was going real good. Then I jiggled a little too hard, gone. I would really recommend 2 people, to do the work. I've installed other windows, VWs, Tenant sweeper, not wrap arounds. They've all be PITA. It does take some experience to get the glass to slide into the new seal. Your suppose to use a rope or cord in the new seal to pull the lip of the seal out for the to slip in. That sounds good and it does help, but not easy to do, without some experience.
Larry
68 C20 327 daily driver
63 C20 292 Camper truck
65 C10 ? Custom Cab AC,PB,PS,$flasher
Lgriffin is offline   Reply With Quote
Old 06-20-2004, 12:29 AM   #3
Seon
Seon's Avatar
Glass shop charges $35 to install a windshield but if it's a used one, they won't guarantee if it breaks .
Seon is offline   Reply With Quote
