The Sauz
Got a New truck
Looks like I'm gonna be on your guys board a bit more often now
I just bought a 79 3/4 ton 4by, 44 in the front and I think a full floater 14 bolt in the back, 4.10 gears, 350 with a 4 speed,np205, camper package, with lot of free rust for only 400 bucks, the cab needs basically replacing, but luckily my buddy has a spare one sittin in his front yard, and the clutch only sits about a 2 inches from the floor. So the questions will start right here, can someone verify from the pics that i've got the back axle identified right, also this is my first manual truck,so is there any way to adjust the clutch in these, or should i just go lookin for a new one, and how much trimming am i going to have to do to fit 35's with a 3 inch body lift in it?, She don't look like much now, but I'll keep the pics comin as she gets built in the next few weeks
68 lwb 2wd (spread between 3 garages) 72 Burb - Flat Deck 92 Yukon 3" lift - 33's - the new bush pig 01 Sierra - Daily Driver (for now) Last edited by sixty8chev; 07-05-2004 at 06:57 PM. |
Professional Grade
Most definitly a 14 bolt out back, very tough rear end... As far as the clutch goes, you may have a broken clutch, or the throwout bearing may be shot... You'll probally have to replace it. Either that, or you can check under the dash and make sure that there are still two springs holding the clutch pedal up, and that they are in good shape yet.
You should try taking that truck to the local mud hole, with those tall skinny tires and 4x4, you'll probally do pretty good ![]() Overall a pretty solid looking truck, less rust than I have!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
california fill
we have a criminal on our hands. you stole that truck!
pc |
The Sauz
I'll take a picture of the floor and the drivers side soon, then you'll get to see what the great white north can create for rust, it's pretty much gone right to wear the seat mounts to the floor, but the box and front clip are relatively rust free so I think i got somethin good to start with once i get the cab replaced
68 lwb 2wd (spread between 3 garages) 72 Burb - Flat Deck 92 Yukon 3" lift - 33's - the new bush pig 01 Sierra - Daily Driver (for now) |
