Old 06-19-2004, 12:53 PM   #1
68C15
blood type; Retumbo
68C15's Avatar
brake question
I just checked my rear brakes today & found backing plates worn badly not allowing shoes to self adjust. got on the phone to carquest & napa & dealer with no luck on availability. my rear is from a '80 C10 with 11"x2". has anyone ever found these, have any for sale? would consider changing to disc but not sure about prop. valve issue. I know I could repair mine by welding the wear pads back up & grinding flat again but it is my only ride now so down time is a problem.
thanks Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-19-2004, 05:45 PM   #2
cableguy0
just braze em up or weld up either way if fine and make sure you use never seize on the contact spots so that doesnt happen again
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-19-2004, 06:31 PM   #3
john
member #16
john's Avatar
If they aren't in too bad of shape i have used a sharp center punch on the pad. The punch raises the metal and gets rid of most of the groove then flatten with small hammer add anti seize for lube and your good to go. John
john is offline   Reply With Quote
