Old 06-19-2004, 06:26 PM   #1
ocbaud
Garage Queen Material
help me wire THIS.
Primary Harness (h1) 12pin connector:
orange-(-)500 mA armed output
white- (+)/(-) parking light flash output
white blue- activation (no need!)
black/white- (-)200 mA dome light output
green- (-) door trigger input zone3
blue- multiplexed input/ trunk (-)
violet- (+) door trigger input zone3
black- ground
brown- siren(+)
red- (+) 12v constant power
red/white-(-)200mA channel 2 validity output
H2-6pin
blue- (-)status/factory rearm
blue/black- (-)third ignition output
gray- (-)hoodpin switch
brown- (+)brake switch shutdown
violet/white- tach input
black/white (-)neutral safety
white-2 pin
status led port
blue 2-pin
valet switch port
black 3 pin
programming port
white 3 pin door lock outputs
blue
(-)unlock
(+)lock
white
(+)unlock
(-)lock
white 4 pin
shock sensor input
white 3 pin aux harness
purple/black (-)channel 4 output
green/black (-)factory disarm
gray black (-)wait-to-start
hahaha, its gonna be a pain, isnt it.
ocbaud is offline   Reply With Quote
Old 06-19-2004, 07:17 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Does the company who made the alarm not have a website? Maybe they have installation instructions on the site you can download.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-19-2004, 07:44 PM   #3
86 Red_Bowtie
86 Red_Bowtie's Avatar
Exclamation
Have somelse do it if nothing else at least it will save you all the trouble.
86 Red_Bowtie is offline   Reply With Quote
Old 06-19-2004, 08:35 PM   #4
ocbaud
my friend got the installation book from his work.
and now, they dont have the installation guide on there site.
Old 06-19-2004, 11:32 PM   #5
bagged74
its just $$$$$
bagged74's Avatar
If you dont know what you are looking at, you should have it professionally installed. Because if you try it and screw it up, they are gonna charge you a lot more to do it later.
bagged74 is offline   Reply With Quote
Old 06-19-2004, 11:40 PM   #6
ocbaud
okay, try and figure me this out.
i got the alarm working perfect(besides putting my interior back together), so that that you nay sayers.
but the only problem i'm having is with my door lock actuators. everytime i arm the alarm, they dont lock, and everytime i disarm it, they dont unlock. i dont believe i need a relay, but i could be wrong.
Old 06-19-2004, 11:43 PM   #7
bagged74
its just $$$$$
bagged74's Avatar
no you dont need "a relay", you need two of them.
Old 06-19-2004, 11:52 PM   #8
ocbaud
really? my friend asked his boss(working at a car audio install shop) and he said no.
how would i wire the relay up and where would i buy them at?
Old 06-20-2004, 12:00 AM   #9
bagged74
its just $$$$$
bagged74's Avatar
you should be able to get them at your friend's car audio install shop.
terminal 30-- +12v
terminal 85-- +12v
terminal 86-- -(lock or unlock output from alarm)
terminal 87-- +output to lock or unlock wire in truck
terminal 87a-- not used
Old 06-20-2004, 12:10 AM   #10
ocbaud
terminal 30-- +12v
terminal 85-- +12v
sweet. thanks
it suprised me that i was able to wire this alarm up so well. i've never installed an alarm before, and this is a pretty complicated one.
Old 06-20-2004, 01:14 AM   #11
ocbaud
terminal 30-- +12v
terminal 85-- +12v
so the termial 87- goes to the "+" of the actuator? and the "-" wire needs to be grounded. where should i ground it at?
so it should be like this:
terminal 86- "-" lock output from alarm
terminal 87- "+" lock output from actuator
doest that sound right?
Old 06-20-2004, 07:06 AM   #12
1972C10
1972C10's Avatar
Ive supervised a few alarm installs and they have to have them relays for the acutator one to lock and other the unlock right? Cause on all the acuators ive seen one does lock other does unlock.
1972C10 is offline   Reply With Quote
Old 06-20-2004, 10:45 AM   #13
bagged74
its just $$$$$
bagged74's Avatar
did you add the actuators yourself? If so disregard my wiring directions as you will need to wire it differently!
Old 06-20-2004, 02:25 PM   #14
gldevall
gldevall's Avatar
Take it to the shop your friend works for and have them do it. Then if soemthing goes wrong you can take it back to them and have them fix it. It would save a lot of time and heartache.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 06-20-2004, 06:27 PM   #15
ocbaud
its all done cept for the actuators.
yes, i added them myself. they work fine when hooked directly to a battery.
Old 06-20-2004, 06:35 PM   #16
ocbaud
how will i need to wire them?
there are 2 wires coming from the actuators. and 2 wires coming from the alarm.
blue
(-)unlock
(+)lock
Green
(+)unlock
(-)lock
how would i hook those up to a relay to make it work?
Old 06-20-2004, 06:37 PM   #17
ocbaud
on another board, someone said it needed to be like this:
you need 2 relays
relay 1
85 blue brain alarm* unlock******
86* 12v fused******
30*unlock wire from both actuator*****
87a*** ground*********
87* 12volt fused
relay* 2
85* green brain alarm lock********
86* 12v fused******
30** lock wire from both actuators
87a* ground*************
87* 12v fused
Old 06-20-2004, 10:01 PM   #18
ocbaud
so you guys know, the above relay diagram is correct.
i now have power door locks.
all i have left to do is tape everything up and assemble the dash back together
