Old 06-19-2004, 07:22 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Big block chevy bore/stroke number
I though I found a 454 but i ran the number and it ended being a 366, what us the difference between bore and stroke between the 2? Also, would the heads be the same?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 06-19-2004, 07:59 PM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
A 454 and a 366 are completely different animals. The 366 has a taller deck. I think that the stroke on the 366 is a 3.76 but I am not positive.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 06-20-2004, 03:16 AM   #3
jimfulco
366 bore is 3.94", stroke is 3.76". The following is from Mortec:
We are asked about the 366 BBC "tall deck" truck engines often. Unfortunately they are not worth using as a performance motor. Safe overbore is .060" and that doesn't make much. They can be stroked but then you can find pistons to match "off the shelf" and so custom pistons are required. You can "harvest" the heads, oil pan, valve covers, crank and rods from them to use on another larger bore Mark IV BBC. Otherwise, don't waste your time or money. The 366 makes a good low power heavy duty truck mule engine or an excellent boat anchor.
jimfulco is offline   Reply With Quote
Old 06-22-2004, 12:20 AM   #4
Blue85
Oilfield Trash
Blue85's Avatar
Will the 366 motor mounts work with a 454?
87 Chev 3+3 4x4
