How to get C10 2WD short/fleet to hook...
How can I go about that if I've already got:
383: 4-bolt main block Eagle 3.75" 4340 crank w/ 6.0" 4340 rods SRP forged dished pistons 10:1 Comp Cam XE274 w/ Magnum roller rockers 1.6 ratio Dart Iron Eagle 200cc heads 2.02/1.60 Speed Demon 750 mech. secondaries I'd LIKE to pull 12's in the 1/4 when the motor is finally broken in. I'm open for any suggestions.
'71 Chevrolet C10 shortbed - 414" LQ9/4L80e/S91 turbo --- PROJECT! '99 Chevrolet Camaro Z28 A4 Yank 4200 stall/AZPS 03 cam (242/248 .621"/.615" @ .050" lift)/UMI 4130 suspension/True Duals/Moser 9" 3.73/AR Torq Thrust M's Black |
what transmission, rear gears, and tires are you running?
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
With that engine, coupled with a Th350, along with a posi rear end with gears in the 3.4x-4.1x, and a good hook, I can GURAN-DAMN-TEE you'll go 12's!
If you got leaf springs in the back, I would recommend a flip kit, with spring clamps in front of the axle. |
Trans: TH400 Hughes-built w/ 2500 stall
Rear end: 3.73 Eaton posi 12-bolt rear Tires: 295/60/15R BFG Drag Radials
I have almost the exact same setup. Where can i get a flip kit for it??
#6 | |
By the way, I AM running coils. Any way I could get the hook I want without going to a flip kit w/ leafs?
Fabricate till you "puke"
Your coil setup will hook much better than the leafs, & much less hassles. The long trail arms make a good traction bar. It sounds like you have the rubber on the back, but may find that the truck will hook better on the strip than on the street.....i would take it out & run it after you get the fresh mill broke in, see how it does, & work from there
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Go to www.hotrodstohell.net and check out the truck arm upgrade kit. I just ordered one and will post results...
#10 | |
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
My only concern about HotRodsToHell's kit is that I already have the complete 4/6 drop kit from Early Classic, which has springs, shocks, shock mount relocator, and drop spindles. How would this interfere with HotRodsToHell's kit?
Unfortunately, you would lose all that you have done on the rear. You would still retain the rearend and the trailing arms but that is basiacally it. The rear is totally adjustable as far as height as I also have a 4" front drop as well. Steve the owner of hotrodstohell said that the truck would sit as low as you want in the rear for the front drop to look right. Hope this Helps!
#13 |
Project56 on hold
Suffer: Your rear suspension setup will hook better than a leaf sprung truck. You defintely need to replace all bushings in your trailing arms. The lowered springs you have in the back may actually impede your performance only because they are proabably a higher spring rate than stock. ( You want as soft as a spring as you can get away with for weight transfer )
Also, make sure your ujoints are top notch. You can lose lots of power through the driveline. Of course, make sure you have good trans/motor mounts too.
Shamrock Customs Forever-in-the-Future Custom Shop 2009 Mitsubishi Lancer GTS daily driver 1956 Chevy Stepside rodstoration on winter hold |
