Old 06-20-2004, 10:50 PM   #1
68_Step
Question 454 Carb size
I just purchased a Chevy 78 C-30 with a 454 in it. The carb on it is a Holley double pump 600, #4776. Is this card big enough for this engine? The engine has headers and "may" have a mild cam installed, not sure about that. As a side note, the engine does not seem to have the power I would expect from it. I know there may be numerous tuning problems, but the 600 carb was what first jumped out at me.
Thanks!
Last edited by 68_Step; 06-21-2004 at 07:30 AM. Reason: couls not spell carb right
68_Step is offline   Reply With Quote
Old 06-20-2004, 11:03 PM   #2
SanitysBane
wicked man, u know that the 3/4 77 454 was the fastest thing around in the day. well xpt for the 'vette but it could give it a run for the money. i am partial to the quadrajet so thats what i would put on itplus its a 750 CFM
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-20-2004, 11:22 PM   #3
stepside454
stepside454's Avatar
I agree with Sanity on the Q-jet, but to answer your question, I say no, not only is 600 cfm not enough, a mechanical secondary is not the right set up .
It depends an awful lot on what max RPM you intend to run it to, with it being stock, with maybe just a lil cam, Im gonna assume youll stay within 5000 RPMs. In that case Id go with either a Q-jet, or a 670 Holley street Avenger(vac. sec. ), the 670 might like a 1"open spacer under it on a 454, or a Demon 725.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 06-20-2004, 11:23 PM   #4
SanitysBane
if u want more performance i would look at the edelbrock heads that have the tiny combution champers to help that low compressoin ratio out (7.4:1)
'88 K5 Blazer
Old 06-21-2004, 08:04 AM   #5
68_Step
Stepside454: Which Demon 725? Road Demon Jr or the Road Demon?
If I use a Q-jet, will I have to replace the manifold? Isn't the 600 Holley is a squarebore, and the Q-jet a spreadbore?
Old 06-21-2004, 03:01 PM   #6
SanitysBane
u could use an adapter, thats what i have
'88 K5 Blazer
Old 06-21-2004, 06:07 PM   #7
stepside454
for your application the jr. would probably be fine. as far as well a q-jet fit, what intake do you have ?
Old 06-21-2004, 10:11 PM   #8
68_Step
Stepside454: It is a Preformer Z-0 manifold
Old 06-21-2004, 10:20 PM   #9
stepside454
I assume you mean performer 2-O. if thats the case, it is compatibal with both square & spreadbore carbs
