Gentleman Jim Driver
What did you get done this weekend?
Well, I'm pretty sure Ken's on vacation, so I'll post this...
I finally got my 1980 Indy Hauler running on Friday. That was the culmination of the worlds longest engine swap. I took out the original 350/TH350C and replaced them with a Goodwrench 350 and TH700R4. I used an Edelbrock Performer intake and a Summit rebuilt Quadrajet. I also used Summit ceramic coated headers and a Dynomax dual exhaust system. I've been working on this on and off for a few months now so it's good to move on to something else. Next will be the front suspension on that truck and today I picked up a sway bar for it since it didn't have one originally. So what did you all get done, show pics if ya got em...
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
Garage Queen Material
got my alarm hooked up.
BAD BOW-Silverado XST
Fixed the broken pivot bolt for the driver side window. It won't break again. Fixed a problem with stereo amp. Music is just not the same with dual 12" thumpers.
![]() Fixed the electrical constant signal problem. Turns out I replaced a burned bulb with an incorrect size bulb which duplicated the problem. Replaced the bulb again this time with the correct one and problem was solved. Threw away a few bulbs that were the incorrect size for any lighton my truck. My truck is back on the road after being parked over a week. ![]() |
LED King
I hooked up a 3 air powered horns and a new deck. When I hooked up the deck, There were 2 brown wires and apprently I hooked up the wrong one as my parking lights flash to the music now.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
My truck got re-painted.
REplaced my ball joints and mowed grass. God it was hot.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
It followed me home?
Got the interior yanked out and herculined the floor of the K5, also went and picked up my new tires.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Slots go on anything!
I did almost nothing. I connected two trans cooler lines on the Blazer, and stayed in the house sick for most of teh weekend.
1974 Jimmy- 5.3/4L80e/NP241 |
Trucker.
Tore down the driver door to get ready for new door panels. Put mirror from my wifes 98 on to replace tired stock mirror.
put in a new Alt. and trans mount. Looked at my dragging brakes and decided i must have stuck calipers. i also started on my crossover filler neck. All in preperation for a one day trip to North Eastern NM.
![]() Join Date: Feb 2004
Got tired of antifreeze in my floorboard so I replaced the heater core in my 76. Also had the A/C checked out 'cause it wasn't cooling good enough. There is apparently a leak somewhere. I just had the A/C redone 2 months ago (new compressor, drier, evaporator core, etc), so I took it back to the shop that did the work. They couldn't tell where the leak was so they vac'd it out, re-charged it and added some dye. I've got to take it back to him later this week to let him find the leak.
Mike ![]() |
#12 | |
#13 |
yeller
I went junkyarding on Thursday, went to the "Back to the 50's" show on Friday...got sun burnt too, installed my headliner, watched NASCAR, and visited by Grandfather on Sunday (Fathers Day).
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#14 | |
yeller
1. Remove the old trans mount bolts (from the trans and x-member). 2. Jack up the trans slightly (enough to slide out the old mount). 3. Instal the new one.
#15 |
"The dude abides"
Well, I decided to find out why the underside of my pickup had what appeard to be gear lube all over after a highway trip. Found the differential seal on the front axle was leaking. Tore that off to find water in there. (LOTS of water) which is disturbing because I know I haven't went through any water with it since I have had it. (bought it in April of last year) So I clean and inspect the dif. All looks good so I put the cover back on and fill with clean (water free) lube. I then decide to check the transfer case for water. Thankfully, no water in there. I then decide that I better check the rear just in case. I pull the cover on that one to find that someone cracked the cover earlier and put this tar crap all over it to seal it back up. Good thing though, no water!
![]() On my way into town one time (I was driving my 69 Cutlass since it was nice) I feel something kind of like a grinding. Get home and leave the Cutlass outside while I work on the pickup. I come out to find what appears to be gear lube on the passenger rear tire. Check it out and I have a bad seal and bearing on that side so that will be my next project once the pickup is out of the garage! It never ends.......
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
#16 |
i did nothign, still waiting to get to houston to get the fuel lines and sending unit for my truck, going to be putting in an intank eletric fuel pump, ill let y'all know how it goes.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
#17 | ||
![]() ![]() slightly nothing, i had to jack the trans up until it hit the bottom of the cab to get the OLD colapsed mount out. The new mount was still an 1" taller due to the fact the old one was flattened. i couldnt jack it up any further so i unbolted the drivers side of the trans crossmember and loosened the passenger then pried the crossmember down far enough to get the new mount in. after bolting the crossmember back up i first bolted the mount to the crossmember and tried to bolt the trans to it. the trans was about 1/4" to far to the drivers side and 1/4" to far forward. i decided to be done with it for the night and tried again yesterday after work. i unbolted the mount from the crossmember and bolted it to the trans first after jacking the trans up again, it bolted to the trans fine and as i lowered it, it dropped into place so i could bolt it to the crossmember. was hard on saturday, but after rethinking how to do it i dont consider it to be that hard of a task. NOT 10 min. but not hard. Now... if the old mount hasnt collasped than it wont be any harder getting the old out than getting the new one in. in my case the new one was an 1" bigger. |
#18 |
Didn't do nothing , except cleaning and vacuuming "Ye Old Reliable"
While I was cleaning the sides of the trunk , I pushed a little with the cleaner tip on the rear fender and dig a little hole in it... ![]() Must be a hell of a vacuum cleaner ! ! ![]()
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents |
#19 |
Right turn Clyde
Take the nut off the transmission mount, raise the transmission up, pull the crossmember out, take transmission mount off, install new transmission mount, install crossmember, lower the transmission (easy), put nut back on the transmission mount.
Removing the crossmember might seem silly, but I think it helped a lot when I replaced mine. Plus its something else you get to clean up and put back on, if you like that kinda stuff.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#20 | |
Happy to be here
![]() Join Date: Mar 2000
#21 |
Ultimate Diesel Dude
I got my turbocharger installed!
![]() Ken, I love Destin too! I think that's about my favorite place in the whole world. I've been there twice, once a few years ago with my family on vacation, and once last year with my wife on our honeymoon. Actually, last year we stayed in a condo at Navarre Beach, a few miles west of Destin. That whole coastline is absolutely awesome. We were planning to go back this summer, but I think it will be too hot by the time we can get away. Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
#22 |
world class smart ass!
My brother and I took his Blazer out for the first time, it still don't run but it's damn close, just a money issue now..
Aric 75 2WD BLAZER (never ending project) -some day maybe- 02 2500HD CREW CAB 4X (daily drive) -8" lift 37s and 22s- ____ ![]() Last edited by bagged78; 06-22-2004 at 11:14 PM. Reason: wrong pic attached |
#23 | |
Happy to be here
#24 | |
Happy to be here
#25 |
He has almost turned into a man-whore tring to get the money, but no luck with that just yet!! HA HA...
Aric 75 2WD BLAZER (never ending project) -some day maybe- 02 2500HD CREW CAB 4X (daily drive) -8" lift 37s and 22s- ____ ![]() |
