06-21-2004, 11:11 AM | #1 |
Before and After
HEI and Header Questions
I know that the swap for the HEI unit is a no-brainer, but will I have to recurve the unit for the engine that I am building?
Are the exhaust ports all the same on all Small blocks? even the Vortecs? Are there any sites that would give me info for the distributor question.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
06-21-2004, 03:01 PM | #2 |
HEI's are a drop in, nothing else to do (except make sure you aren't off a gear or something)
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
06-21-2004, 04:30 PM | #3 |
you do have to run a new power wire for an hei to eliminate the resistor wire as well as eliminate the yellow wire from the starter
06-21-2004, 07:03 PM | #4 |
Fabricate till you "puke"
i agree with both guys on the HEI, its a pretty bolt in swap, with addition of a wire from IGN unfused in the fuse box(full batt voltage). As far as a recurve, it will help your power band & mileage. Crane puts out a nice kit , vac advance can + springs for the mech advance.....the instruction is also good! It will take a little time 1st time around, but after a time or 2 , you will have a new "trick" that you can keep As far as ports & header match up, you should be ok for most apps.....if you try to run some monster heads , like a 12 or 18 degree (roundy pounder stuff), you will have issues with headers. Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
