Old 06-21-2004, 05:33 PM   #1
hotrodhomi
hotrodhomi's Avatar
Question Harmonic balancer
Will a harmonic balancer from a 305 work on a 350? Is this bad?
hotrodhomi is offline   Reply With Quote
Old 06-21-2004, 05:43 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
It will work, I dont see anything bad happening from it. Just as long as its good and not slipped or something it will work fine.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 06-21-2004, 06:39 PM   #3
78SilveradoSWB
78SilveradoSWB's Avatar
It should work, since both are small blocks and are the same block.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 06-21-2004, 06:51 PM   #4
PHOENIX
Timing mark on damper may be different. Not sure though, something to looking into.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-21-2004, 07:05 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
Yep, Eddie's right. As far as I know, all the 305's had the timing mark at 12:00. You will need to find true TDC and make another mark if you are using a timing pointer at 2:00. Also, I'm not real sure a 305 dampener will dampen harmonics like a true 8" 350 one. Personally, I wouldn't mess with it.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-21-2004, 07:08 PM   #6
hotrodhomi
hotrodhomi's Avatar
The timing chain cover I'm using is from the same motor as the harmonic balancer. So the timing should read correctly, right?
Old 06-21-2004, 07:41 PM   #7
1972C10
1972C10's Avatar
They will work just the same. and they had 305s with 2 o clock pointers as well as 12 the early model ones were 2 later ones were 12 o clock..
1972C10 is offline   Reply With Quote
