Old 06-21-2004, 08:45 PM   #1
TIMSPEED
TIMSPEED's Avatar
Fuel Cell Question: We don't need the RETURN line right?
When I put the fuel cell in my 75, I can just cap the RETURN portion on the tank, right? Also, I can remove my Charcoal Canister, because the fuel cell has a pressure relief valve built-in, right?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-22-2004, 07:29 AM   #2
Mike76251
The purpose of the return line is to help prevent vapor lock by circulating fuel back to the tank.
I would say you would be okay blocking the line at the tank but if you suddenly have a bad case of vapor lock you will want to hook it back up.
Mike76251 is offline   Reply With Quote
Old 06-22-2004, 06:43 PM   #3
TIMSPEED
TIMSPEED's Avatar
I do believe I don't have a return line right now, because where would it come from? The fuel pump doesn't have a return line going off of it..
See Them Here
Old 06-23-2004, 10:25 AM   #4
Mike76251
If you have a two line pump then you don't have a return setup.......like you said.
Just cap it well at the tank then and good luck.
Old 06-23-2004, 03:59 PM   #5
bagged81
Signals in the bumper.
bagged81's Avatar
I dont have a return line on my cell.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 07-07-2004, 08:06 PM   #6
loweredd
www.loweredd.com
loweredd's Avatar
With a stock"ish" manual fuel pump, you shouldnt need a return. The return is to let excess fuel back to the tank, like in the case of an electric pump, so it doesnt burn itself up.
loweredd is offline   Reply With Quote
