Old 06-21-2004, 11:37 PM   #1
greasemonkey
greasemonkey's Avatar
u bolts
Does anyone know what kind of u bolts I need to get for front and rear suspension on my truck? I need the 4 that hold the lower front control arms to the crossmember, and the two that hold the rear axle to the trailing arms. I can get ubolts at the hardware store, but I don't know if there is a specific grade/type bolt I need to get. I don't want to reuse the old ones, they're kinda rusty and probably weakened from 35 years of use.
Thanks,
John
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 06-22-2004, 08:58 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Front ones from GM dealer. Do not use hardware store junk for this. You need top quality.
Rear ones from any spring shop. Look in your local phone book for one.
Old 06-22-2004, 10:02 AM   #3
greasemonkey
Thanks Tx Firefighter. I asked at Autozone if they had them, but the old lady (manager) just looked at me like she didn't know what ubolts were.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 06-22-2004, 10:54 AM   #4
chevytruckfan
chevytruckfan's Avatar
Yea most of the time they do that, but they dont sell them. For the rear you need 3" ubolt and you can get them from Summit, Jegs, or a local auto shop that specializes in performance or rod and custom shop. As for the front 4X4's use the same thing 3" u bolts. 2wd's the lower a arms are bolted to the crossmemeber with regular bolts. You can get at the local hardware store just make sure they are the same length and are GRADE 8 bolts.
chevytruckfan is offline   Reply With Quote
Old 06-22-2004, 05:46 PM   #5
gutterman01
bought mine from chevyduty.com 11.95 each for the rear
gutterman01 is offline   Reply With Quote
Old 06-22-2004, 06:46 PM   #6
Tx Firefighter
Fraid not ghostrider. They use U-bolts, not regular bolts. I wouldn't trust my life to unknown hardware store junk. Buy new GM U bolts. They're cheap.
Here's a picture of a lower control arm U-bolt..
Old 06-22-2004, 07:22 PM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I don't know if your '69 has the 7/16 in front or the 3/8. The earlier '67 and '68 had 3/8" u-bolts and several board members have had them break at the most inoportune times...like going 70 on the freeway. It makes for a very sharp and unexpected turn!!!! I am going to upgrade mine to 7/16" as soon as I can find the time...need to put the new cab on first!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-24-2004, 01:50 AM   #8
jlmtrout
Try LMC truck catalog. You might have to drill the holes larger as they don't off the 3/8 any more. Good luck and keep on truckin'.......Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
