Old 06-22-2004, 12:17 AM   #1
72longbed
72longbed's Avatar
Question Who Knows The Answers??
OK, here it is.
1. Which one cools better, a clutch fan thats 'Thermally' controlled or a clutch fan thats 'RPM' controlled??
2. Which one eats less horsepower??
3. Can you use a clutch fan from a big block on a small block??
4. Is there a difference in A/C clutch fans vs. non-A/C clutch fans??
Please give your best answers, the member who gets them all right wins a prize!!
72longbed is offline   Reply With Quote
Old 06-22-2004, 01:51 AM   #2
67 cst swb
67 cst swb's Avatar
Ok,...I'll try
answer #1) Thermostatically Controlled cool better... it's controlled by a thermostat to clutch the fan more or less depending on Temp.
answer #2) a Thermo probably is less power robbing due to more free spinning after cooling down therefor the thermostat frees up clutch, but probably also too little to notice a difference in HorsePower. It takes approx. 20-25HP to notice a difference in the seat of your pants feel...
answer #3) B/B to S/B... I'm sure they might interchange as far as bolting up goes, but as far as application goes a B/B requires more cooling so, a tighter clutching type is required
answer #4) (see answer #3) A/C to non A/C... an A/C vehicle requires more cooling, so by the application, for example, a 72 350 1/2 ton truck takes part# 1234 w/o A/C and a part# 4321 for w/ A/C...
DO I WIN...?
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 06-22-2004, 07:32 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
#1 electric cools better due to being placed closer to heat exchanger.
#2 electric consumes less torque (horse power is a mathematical derivative of torque)
#3 sure, if you like the sound of crop dusters under your hood
#4 translates to thermal-centrifugal question
can you tell I prefer electric fans? why do you think car manufacturers use them? any good parts store (sturdevants) will sell you a fan switch to thread into either the intake or cylinder head. intake runs about 15 deg. cooler.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-22-2004, 07:36 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
BTW Bryan, did you get those #s from the book? ha-ha
do you know the #s for these switches as I lost the box mine came in.
Todd
TS46 rings a bell for some reason
Old 06-22-2004, 09:26 AM   #5
67chevemall
67chevemall's Avatar
I messed with ever fan I could find Then gave up
and purchased a Summit 18" electric!
Works so sweet I love it!
I have dims on the sheet metal brackets I made if interested!
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 06-22-2004, 10:31 AM   #6
72longbed
72longbed's Avatar
Exclamation
This is good stuff so far, but I think there might be some confusion. I am not comparing 'electric' fans here at all. When I ask about the two types of clutch fans, they are not electrically activated. RPM vs. Thermal is two different types of clutches that were put on GM vehicles. So..........., who has the knowledge of these different clutch fans to be able to offer an educated opinion??
72longbed
Old 06-22-2004, 10:36 AM   #7
67chevemall
Cool Man I got it now!
Speed of the engine or heat to engage fan!
Good Question
Old 06-22-2004, 06:11 PM   #8
Vince M
Vince M's Avatar
The "thermal" clutch has a silicone based fluid in it that gets thicker as it gets hotter which drives the turbine inside it more as the temp goes up. I've never seen the "RPM" units but they must have some sort of centrifugal weight that would drive it as RPM goes up.
Personally I vote for the "thermal" unit. It only uses horsepower when it needs it.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 06-22-2004, 10:00 PM   #9
jimfulco
The non-thermal-clutch viscous-drive fans sound like an airplane all the time. The thermal-clutch fans only sound like one when the radiator gets over a certain temperature.
jimfulco is offline   Reply With Quote
Old 06-22-2004, 10:30 PM   #10
68C15
blood type; Retumbo
68C15's Avatar
the main problem some ppl have with the thermal units is if there is too much gap between the rad. & clutch it does not come on soon enough. same thing with not having full shroud.
I personally cannot think of a reason to use the centrifugal type. by the time they engage you are going fast enough to have airflow without it.
what it comes down to in my opinion is either run electric or thermal with fan 1/2 way into shroud.
hopes this helps clear things up a little
