Old 06-22-2004, 03:04 AM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Serpentine Belt accessorie drive
Has anyone seen a new style serpentine belt used on an older truck? I saw it once and it looked ultra clean, looking for more pics when i find some ill post them.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 06-22-2004, 04:03 AM   #2
sam's 72
I have a set up installed on my 383 ( which is not running yet ) working too much! The set up that I have is off of a 98 chevy truck vortec engine. It bolted right up except for one bolt on pasagener side head. Had to redrill and tap, but it is nice. Once I get a chance to get back to work on it, I will try and get some pictures posted. I have a few I have already taken, just been out at work. Working a unit shut down
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 06-22-2004, 10:26 AM   #3
UP GRADE
one set closer
UP GRADE's Avatar
ha that will be great post them when you get a chance.
UP GRADE is offline   Reply With Quote
Old 06-22-2004, 10:53 AM   #4
rickspickuppart
we put them on about everything we build. Usually from 92 - 96 trucks because they are mostly steel and alot easier to have plated.
Shawn
rickspickuppart is offline   Reply With Quote
Old 07-11-2004, 05:44 PM   #5
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Shawn,
Can you spell out a few more specifics/tips/pointers on the conversion to factory serpenting systems on earlier V8's? I'm thinking about this for our '84 305 in the '69 C10, and have these questions:
1) Short or long water pump? Is the water pump different for serpentine setups?
2) What about non-PS or non-AC trucks? Are there extra idler pulleys available for such?
3) Which bolt holes are necessary on the block/heads/manifold/etc. to accomodate the serpentine brackets?
Thanks...SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 07-11-2004, 11:14 PM   #6
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Isn't the water pump reverse flow for serpentine systems?
toddtheodd is offline   Reply With Quote
Old 07-11-2004, 11:51 PM   #7
WB72
Before and After
WB72's Avatar
I thought something had to be reverse. Or is that me thinging again?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 07-12-2004, 10:23 AM   #8
rickspickuppart
The fan water, pump and clutch all need to be for a reverse rotation. If the factory (72) fan shroud is used the fan will need to be trimmed to fit in the opening.
Shawn
Old 07-13-2004, 12:32 AM   #9
Blue68
Blue68's Avatar
Something like this? This is an engine and setup from a '98 Chevy truck, vortec 350. All of the accessories require 'adapting'. The ps pump hoses are metric, the alternator is higher amp, but not a big dea, and the ac uses R134. I'm using a factory big block shroud with the '98 clutch fan.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 07-13-2004, 02:17 AM   #10
Blue85
Oilfield Trash
Blue85's Avatar
Did you have to get a special intake for vortec heads, or just a regular performer series intake? Why didn't you just keep the fuel injection?
87 Chev 3+3 4x4
Old 07-13-2004, 10:20 AM   #11
Blue68
Blue68's Avatar
You have to have a vortec specific intake for the heads since the bolt pattern is different. It's an Edelbrock Performer. I didn't keep the fuel injection due to a rather high cost. It would have been close to a couple thousand dollars by the time the harness was modded, the computer reprogrammed, high pressure fuel pump, etc. Plus, the vortec injection is plain ugly.
For a couple extra mpg, it wasn't worth it. It cranks and runs just fine as it is now.
Old 08-02-2004, 06:10 PM   #12
stickshift_or_walk
Blue68,
I notice that's not the factory compressor. Are you using that for A/C, or just an air pump?
I'm wanting to do a similar setup on my '84 305, so I guess I'll need to drill & tap the head. Got any details (depth, threads, etc?)
Thanks...SSOW
Old 08-02-2004, 08:54 PM   #13
neonlarry
neonlarry's Avatar
Here is a pic from an old post:
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-03-2004, 05:00 PM   #14
Blue68
Blue68's Avatar
SSOW,
I'm not sure what to tell you on the '85 305. I would think the head would have the bolt holes in the head and block. I don't know if they had the bolt hole on the side of the block for the power steering pump lower bracket.
I'd suggest mocking it up if you have the accessories already, or finding someone with a truck that will let you spend some quality time looking at bolts and location. Getting the right length bolt would be easy enough if everything else lines up and is tapped.
And yes, my plan is to use the compressor for a/c. Eventually.
Old 08-04-2004, 02:44 AM   #15
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I have this set-up on my 72 350. I did not drill and tap the head for the inboard upper bolt hole because my last attempt (on a differant make/application) was a miserable failure. It ran fine, no cracks after 4500 miles. I am in the process of buying a Goodwrench crate motor and want to make sure that the accessory bolt pattern in the head is correct for my brackets. GM Performance parts sells this set up (for over 5 bills)part # 12497869 page 93 of the current catalog. I contacted my local GM Performance Parts dealer to make sure this set up would fit a Goodwrench LM-1 and they said, after calling around, it would work fine using only 2 bolts. I am trying to get a verdict from a corperate GM Tech rep what year goups fit these brackets and wich bolt holes are required.
----Sams 72, How did you index the hole you drilled? Did you go through a water jacket?
====SSOW, the pump on a 91 set-up (aluminum brackets) is metric, I had to have a custom hose made ( for $20) that was metric on one side for the pump and standard on the other side for the box. Early pump will not fit due to pulley differances. Serpentine pulley is not tapered and early is. As far as non A/C trucks there is an a/c delete pulley you can find in the junkyards of the cold parts of the country, otherwise. you can buy an a/c delete pulley in the performance catologs/web pages,look Camaro. Don't know about the power steering delete pulley...But don't think available. Water Pump is reverse rotation think long. 91 c20 pump works fine at Nappa. As far as bolt hole requirements initial verdict from Daughtery Chevrolet in Sacramento is 2. 1 in passenger side, outboard upper head (same as ours) and one in lower block (where old style eng monts were). I think one is required inboard passenger head just below manifold but am awaiting responce via e-mail from GM Performance parts corperate. Will post on this thread what I find out.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 08-04-2004, 09:03 AM   #16
stickshift_or_walk
Which setup is best - steel or cast?
Chickenwing,
Thanks for the info and specifics. That helps.
Ok, I've been pursuing one of our favorite hobbies, climbing through weeds and over various carcasses at the local salvage. I've located two setups I can get complete for $150 (each), including all pulleys, alt, AC, PS, etc. Neither have the air pump.
I'm not sure about the years, but the earlier one has steel brackets. All bracketry on this one bolts to the front of the engine, and it looks a little less crowded.
The later one is cast, and has a bracket for the rear of the alt that uses the front bolts of the exhaust manifold. This presents a slight problem since I'm using the mid-80's stock exhaust manifold that is a solid log and bolts underneath, so the bracket can't fit the bolt holes.
Based on this, I'm leaning toward the steel setup, unless someone knows something I don't...
Thanks...SSOW
Old 08-04-2004, 07:18 PM   #17
chickenwing
I like the thought of the steel brackets. My cast ones have not not cracked but I wonder if they will. The steel alternator bracket you mentioned: I trimmed the exhaust manifold mount piece off. The bracket just goes from alternator to power steering pump now. Go with what blows your skirt up.
Old 08-05-2004, 10:17 PM   #18
soala70
soala70's Avatar
how about on a BB?
bogey5
soala70 is offline   Reply With Quote
