Old 06-22-2004, 04:34 PM   #1
low 84
low 84's Avatar
blew out a shock?
my truck has been sitting for the most part the past two weeks and a little circle of fluid was forming under it slowly. i stuck my finger in it and it looked like break fluid at first so i figured a had a busted breakline. i got underneath it today to narrow down what the problem was and it looks like my shock blew out. the only thing thats wet is the lower half of the shock and where its been leaking on the lower control arm. this is a d-tech after market drop shock and its the one that is supposed to go on the amount of drop i have.
so what would cause this seal to go out? is it from sitting so long (i havn;t driven it much the past 6 months). another thing is that when i put the shocks on like 2 years ago i put the on upside down, so the canister part was on top and the smaller shaft on bottum. i didn't figure it would matter because it should still dampen the same either way. could the seal facing downwards with the fluid above it casue it to leak like that? its just wierd b/c i've had them on like that for 2 years
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 06-22-2004, 04:53 PM   #2
ocbaud
Garage Queen Material
i think i remember reading awhile back about mounting the shocks upside down, not just the dtech ones, but others, how it would affect the ride.
it sounds pretty logical that having it mounted upside down would cause it.
letting it sit for a long time, having all the fluid ontop of the seal, and the seals hardening alittle bit, it could happen i guess
ocbaud is offline   Reply With Quote
Old 06-22-2004, 05:30 PM   #3
Prerunner1982
Prerunner1982's Avatar
the shocks on my mountain bike did the same thing, except it looked like Ketchup. took a bit for me to figure out what it was, ends up it was coming out of my bike hanging from the ceiling. I had rancho RS5000s on my truck that were shot, but of course they were originally for an s-10 blazer so i figured that had alot to do with it, but i had them on my truck for about 3-4yrs. So i figure they were pretty worn out anyways.
Prerunner1982 is offline   Reply With Quote
Old 06-22-2004, 06:03 PM   #4
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
I am pretty sure the instructions with the D-Tech's says to mount the reservoir side down, and not to do it upside down.
If you need a new set, let me know.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 06-22-2004, 10:20 PM   #5
low 84
low 84's Avatar
i know its mounted upside down. i've known ever since i put them on that way. i'm just wondering what caused it to fail after 2 years
what size drop are yours for and how much$$?
'05 1500 Crew Cab
RIP
Old 06-23-2004, 08:06 AM   #6
Izzy
Trucker.
Izzy's Avatar
I'd imagine if it was mounted upside down some junk could have gotten down in the shaft seal and caused it to leak.
Izzy is offline   Reply With Quote
