06-22-2004, 06:46 PM | #1 |
Saving 1 truck at a time!
Whose using the Energy suspension kit
Anyone running the cab, core mounts? How do you like them? They are less expensive than the stock units!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
06-22-2004, 08:17 PM | #2 |
Fabricate till you "puke"
I have cab mounts, & like them. they do make a bit harsher ride in the old truck, but my clutch works sliker n chit! The old longhorn has a steel tilt nose, so only 4 bushings to control the "squirm".....the doors shut nice too crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-23-2004, 12:26 AM | #3 |
Cool...that is all I need to hear. I am going with them as well.
