Old 06-22-2004, 08:12 PM   #1
trailmaster
Polyurethane Body Mounts
Does Anyone Know If A '73-'87 Polyurethane Body Mount Bushing Kit Will Work With A '65 Body? I Would Like To Use Them Between A '65 Body And A '86 Frame.
Thank You
trailmaster is offline   Reply With Quote
Old 06-23-2004, 04:28 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
You'll probably have to move the mounts on the frame to match the mounting points on the cab, doing this and you can use the mounts. If you just sit the cab on and drill holes in the cab, probably not.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-23-2004, 11:50 AM   #3
trailmaster
Mounts
I Guess My Question Is, Are The Body Mount Bolts And The Mount Shapes/configurations Such That A '73-'87 Body Mount Bushing Set Will Fit A '60-'66 Cab. I Am Moving The Mount Brackets On The Frame To Match The Cab/body. I Am Looking For A Bushing Set That Will Work Nicely With Both The Body And The Frame. DAYSTAR has a kit for '63-'66. I will probably buy that and make/modify the frame brackets to fit the bushings.
