Old 06-23-2004, 12:51 PM   #1
SanitysBane
88' sending unit wiring
ok on the connector to the sendingunit there are 3 wires, red, black, and a white/tan colored wire. which one of these goes to the guage? and what are the other 2 for? thanks
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-27-2004, 02:49 PM   #2
SanitysBane
ttt, any one got a clue? i've got a red/pink wire in the middle with a black with white strip on one side and a tan one on the other.
'88 K5 Blazer
Old 06-27-2004, 06:58 PM   #3
ChevyTech
I will assume you have a 1988 full size truck with TBI
Which seding unit are you refering to?
The fuel tank sending unit has a wire for the gas gauge, a wire for the fuel pump, and a ground wire.
The oil pressure sending unit has a wire for the oil gauge, a wire to the fuel pump, and a power supply wire. Trucks with TBI (throttle body Injection) have a relay that suplies power to the fuel pump for starting. When the truck starts the power for the fuel pump goes through the oil pressure sender.
If this does not answer your question, reply with vehicle, engine, fuel system and which sender information.
Old 06-28-2004, 05:05 PM   #4
SanitysBane
all right its a 1988 chevrolet long box, it came with a 305 and a 32 gallon tank, it has tbi, im taking the fuel sending unit out and puting it in my 83 chevrolet, i've allready got the sendingunit to fit in the tank i just don't know which wire goes were.
'88 K5 Blazer
Old 06-29-2004, 11:23 AM   #5
ChevyTech
You should have a purple wire (most likely your red, pink ), which is for the gauge.
Tan with a white stripe was the power to the fuel pump.
Black with white tracer on it, was the ground for the fuel pump.
Hope this helps you
Old 06-29-2004, 01:30 PM   #6
SanitysBane
thanks, hooked up and it worked
'88 K5 Blazer
