Old 06-23-2004, 03:03 PM   #1
azdeltawye
azdeltawye's Avatar
C-series Front crossmember and suspension swap question
Is it possible to swap a coil spring front suspension assembly from a ’65 Chevy into a ’60 Chevy? Upon initial inspection, I noticed that the ’60 has boxed frame rails which could make the swap more difficult. But my main concern is; are there any major fitment issues that would prevent installation of the late model crossmember into the Apache?
Any info would be greatly appreciated.
1965 C20, 350 cid, '71 front Disc brakes, NV4500 5-spd, 4.10 FF 14-bolt
azdeltawye is offline   Reply With Quote
Old 06-23-2004, 07:04 PM   #2
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
YES it is possible I switched my 62 with a 64 front suspension. The only thing is only about 1/2 the holes will line up the other half are off about 1/4" and one on each side has to be redrilled. I used my 62 steering linkages just had to adjust the toe in a little bit. It is kinda tricky with the boxed in frame but they left it open on the one side of the frame rails to reach the 7 bolts on each side. I swtiched mine with the motor still in!!! I would advise to take it out if possible it would be alto easier but not impossible to do with it still in. Good luck.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
Old 06-23-2004, 07:40 PM   #3
azdeltawye
azdeltawye's Avatar
Thanks.
That helps alot!
