Iron Thunder
on the disk brake conversion kit it sed to use 68-72 rotors and 73-77 calipers.why can't you use the 68-72 calipers.
What kit are you talking about? There are no 68-70 rotors or calipers, only 71 up had disc brakes. Which rotors and or calipers are needed would depend on what the spindles were made to fit.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Iron Thunder
the kit is from chevy duty, it has the brackets,bearings and hardwar. it go's 99.95
If it uses a bracket instead of a new spindle it sounds like the bracket is made for the 73-77 calipers. With stock spindles you would use 71-72 5 lug rotors.
That kit uses car rotors and calipers you would have to have them plugged and drilled for the truck bolt pattern.
Tim |
