Old 06-23-2004, 04:33 PM   #1
dubie
dubie's Avatar
Leaking water pump
If a water pump were to start leakin, where excatly does it leak from? The reason I ask is I have been blaming this dripping of antifreeze from the lower rad hose on the hose, but i stuck my hand up farther in behind the pulley and it's wet up there. Does anyone have a pic of where this would leak from??
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-23-2004, 04:43 PM   #2
krue
Designated A-hole!
krue's Avatar
If I remember correctly there is a weep hole on the bottom of the waterpump housing, if the seal around the shaft for the pump is leaking, that is where it will come out.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-23-2004, 04:56 PM   #3
SideStepper
No picture, but the common spots to check for water pump leaks would be:
1. Gasket at engine block.
(Replace gasket/sealer)
2. Bolt holes into engine block
(Just remove bolt, not pump..... & use sealer on bolt & reinstall)
3. "Weep hole" in pump housing, located bottom side, underneath shaft.
(no fix, replacement water pump required)
Hope this helps, Good luck!
SideStepper is offline   Reply With Quote
Old 06-23-2004, 06:08 PM   #4
flip66
flip66's Avatar
they are right your weep hole is leaking get you a mirror and look at the bottom of the pump and you will see it. It will be a very slow leak and run down the lower hose.
flip66 is offline   Reply With Quote
Old 06-23-2004, 07:29 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
Tim, here's a few pics, they're kinda hard to see, but you'll get an idea of where the weep hole is.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-23-2004, 07:53 PM   #6
smitty62
smitty62's Avatar
Better get it off.......once they start leaking at the weep hole the bearing goes out in a hurry!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 06-23-2004, 10:10 PM   #7
Gee_Emm
Looks like someone is pissed off at their waterpump :p
Gee_Emm is offline   Reply With Quote
Old 06-24-2004, 12:29 AM   #8
walker
walker's Avatar
Had an s-10, same basic water pump, it started to leak so bad that I started calling the weep hole the pee hole.
If you are into that sort of thing, you can rebuild them with a new bearing and a seal. Rear gasket comes with an engine rebuild set. If you are not then buy a new one, not a rebuilt one.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 06-24-2004, 03:10 AM   #9
71-longbed
Its Magically Delicious
71-longbed's Avatar
my old water pump off my 350 ... looked like the original... it had a very slllllloooooooowwwww leak out of weep hole .. i replaced it even though it still worked .. you could see the yellow crusty trail down the bottom of the pump .... i wonder how much longer it would of lasted ...it had to be leaking for a few years at least
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 06-24-2004, 03:12 AM   #10
71-longbed
71-longbed's Avatar
now you can see the hole :p
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
