Polishing Grille
I have a 70 grill that is pitted and was wondering what is the best way to clean it up and polish it?It has some sand blast pits in it other than that it is a pretty nice grille.THANKS FOR THE INFO
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
SLOW BUT SURE,BUT CLOSER
I used buffin' compound and a pad on a drill on mine. Works but takes some time. Gave up and sold it and got a repop.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
What me ugly?
I used to polish aluminum for a living.. what you need is a grinder-type buffer (3-5000 rpm) a stiff starched polishing wheel (usually yellow or red), a brick of brown jewlers rouge (all this is usually available at a truckstop)... machine the grille first with these to get the smaller pits & roughness out, then go over it with a soft cotton (white) wheel with green jewlers rouge. if you want that "mirro-chrome" finish, use a fresh white wheel with white rouge, then go over it by hand with blue magic hand polish for the silicone sealant. easy, eh?
`70 C-10 LWB Big & Ugly, like its owner... 307 SB - 600 Holley, Offenhauser 360 - Muncie 465, 3:73 Posi, 33" BF-G`s I like my trucks like my women... big & old with 33" feet. ![]() |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Befor you pollish it you will have to sand off the anodizing first. Then you can pollish it to a brilliant shine just as 3rdGenrationChevyman has described. You can pollish it untill the cows come home on the anodizing and it will do nothing but clean it and not take care of the oxidized aluminum under it. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
What me ugly?
oops, left that part out... yes, the anodizing will ned to be gone first, the machine & rouge only works on raw aluminum...some fine wet/dry should do the trick
OK Thanks for the input I'll see what I can get done
Fabricate till you "puke"
Easy off oven cleaner works good to strip the anodized coating.....dont leave it on too long tho! after about 15 minutes, you can put on the rubber gloves, & start rubbing with scotchbrite. This may take 2 or 3 apps, & a good rinse between. I hand sanded & polished mine(twas a long winter!) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
What me ugly?
I gotta keep that in mind! I spent a week sanding the anodizing off`n the sides of a converted city bus rv to polish it... very cool!
